Help with scale numbers
oxygen
Weighed at local grain elevator and here are the numbers
truck by itself
steer axle-3240lbs
drive axle-3000
gross weight-6240
tt + tv- WDH(equalizer) bars disconnected
steer axle- 2940
drive axle- 4200
trailer axle - 5360lbs.
gross weight- 12500
tt + tv-WDH engaged
steer axle- 3060
drive axle- 3900
trailer axle- 5540
gross weight- 12500
tv is Rockwood Ultra Lite, ship weight- 5676, hitch weight- 739
gvwr- 6739, this info taken from web site, yellow sticker on side of tv for dry weight is 5840lbs
tv iv 2012 f150 EB, screw, heavy duty, payload is 2440lbs.
please ?check my math
total gross weight mlnus truck gross, engaged = trailer weight = 5540lbs
tv engaged Wdh minus tv unhitched = 720lbs , weight transfered to tv
tt hitched axle weight minus tt unhitched axle weight = 180lbs.
720lbs. + 180lbs. = 9oolb tongue weight
tongue weight is 16% of tt weight
front axle tv unhitched minus hitched front axle = 300lbs.
engaging wdh put back 180lbs to steer axle
is tongue weight added to tt axle weight to get tt weight?
any adjustments needed?
any adjustments i should make to wdh?
2012 F-150 XLT,screw, EcoBoost-3.5 liter, Heavy Duty, payload 2400
2014 Rockwood 2604WS, Equalizer head
36 REPLIES 36
oxygen
Ron Gratz wrote:
oxygen wrote:
---I likely messed up when I added 200lbs for Dw and our dog(who weighs 60lbs) to the gross weights because they weren't present for weighing.
Also note that rear axle on tv was a calculated value from other weights listed.
I subtracted steer axle unhitched from steer axle with wdh disconnected to get the 300lbs. Is this correct?
Can you post the actual scales numbers?
Also would help to know if you were in the cab, on the scales, or not included in any of the scale weights.
Ron
truck by itsef, no wdh attachd, i was sitting in truck with all 3 weight
front axle-3240
gross tv- 6040
fear axle- 3000, calculated from fist two
truck hitched but bars NOT engaged
front axle- 2940
tt & tv- 12300
trailer -5360
rear axle- 4200, calculated
truck hitch, wdh engaged
front axle- 3060
gross weigh- 12300
trailer- 5540
rear axle- 3900, calculated
Ron_Gratz
Ron
oxygen
2 other questions
1. is wdh to be attached when weighing only truck? I had it removed.
2. tt + tv, wdh not engaged, i left the bars hanging inhead socket..should they have been put into tt?
is wdhand bars considered part of tt or tv or combination of both when it comes to weight numbers?
didn't weight wd by itself, but guess it weighs appr. 100 lbs or so
oxygen
Sorry about messing up with quoted portion of Rons question.
oxygen
Ron Gratz wrote:
oxygen,
There is a discrepancy in your data.
It appears that approximately 220# was moved from the steer axle pad and added to the drive axle pad prior to making the "tt + tv-WDH engaged" weighing.
If so, that would mean your WDH caused 340# to be added to the steer axle -- versus the indicated 300# removed when tongue weight was applied with no WD.
This would mean your WDH was adjusted to transfer too much load.
Is your weight any where near 220#, and is it possible that you moved from the steer axle pad to the drive axle pad prior to making that
weighing?
Ron, thanks for joining the discussion. I always enjoy your posts. I likely messed up when I added 200lbs for Dw and our dog(who weighs 60lbs) to the gross weights because they weren't present for weighing.
Any help with tese numbers would be very appreciated. The more I work with the numbers, the less sure I become.
Ron
Ron_Gratz
oxygen,
Is your weight any where near 220#, and is it possible that you moved from the steer axle pad to the drive axle pad prior to making that weighing?
Ron
oxygen
RCMAN46 wrote:
Trailer Weight is 6260 and tongue is 900 which gives a tongue percentage of 14.4%. I would not do anything to reduce the tongue weight. In fact I would increase it if I did anything.
You are only about 400 lbs over dry weight. I suspect the trailer was not loaded for a trip. When loading keep in mind what it will do to the tongue weight. I would recommend heavy things to the front of trailer.
We just got back from weekend trip minus food in fridge. We travelled light. Why should we go above the 14% tongue percentage?
RCMAN46
APT
Looks pretty good. I would try for a bit more WD to front axle, but if it tows well....
2017 Subaru Outback 3.6R
elivi8
Perfect. Looks like you just about have it. Make sure the weight distribution bars are parallel to the ground and you should be done.
Ryan
2012 F-150 EcoBoost, Max Trailer Tow
2019 Outdoors Timber Ridge 27BHS
490 Watts of Solar
oxygen
I bought the hitck several years back before the tt and bought 1200|12000 size. Equalizer folks thought they would work with this tt.
Decided to try them.
elivi8
In the new trucks ford recommends splitting the difference between unloaded and loaded weight on the front axle. You are close but a little light. You could transfer a bit more weight to the front. The rest looks good. What size weight distribution bars do you have?
Ryan
490 Watts of Solar
oxygen
TomG2 wrote:
How much front axle weight restoration does Ford recommend in your owner's manual? You are over the 50% that others have mentioned.
Tom, could you use numbers to show how much was transfered. is this number the difference between steer axle hitched - steer axcle hitched but wdh disengaged?
oxygen
when adding\subtracting washers, does this primarily affect bar alignment or what else?
oxygen
my manual says approximately 50% change in height adjustment, assume
this would pertain to weight, too
