โApr-04-2015 03:45 PM
โApr-14-2015 02:17 PM
โApr-14-2015 09:23 AM
โApr-14-2015 08:30 AM
โApr-13-2015 08:21 AM
โApr-12-2015 12:21 PM
โApr-09-2015 07:37 PM
โApr-09-2015 07:09 PM
โApr-09-2015 07:08 PM
acritzer wrote:
I've tried to wrap my head around this concept and haven't quite gotten there. What if the driveway slopes and then levels out? What if the TV is on a higher grade than the trailer? How do you adjust hitch height with those variables?
โApr-09-2015 05:04 PM
hawkeye-08 wrote:
IMHO, Using the level in the trailer to make sure the trailer is level or nose down slightly will only be applicable if the driveway is level. The driveway looks to be sloped, the trailer should be parallel to the driveway (I measure from trailer to ground front and back, using stripe on side that is same as frame. I used frame to get it right first time, then measured stripe and it was the same, so now I don't crawl under to measure frame from ground).
โApr-09-2015 04:49 PM
โApr-09-2015 04:16 PM
โApr-09-2015 02:06 PM
โApr-08-2015 05:54 AM
acritzer wrote:
So the "parallel" bar comment is kind of the last concern? Just as long as the bar won't run into the frame?
I've had 5 links on before and it was only hanging down a link or so past the trailer frame. It also meant that the bars were angled up a decent amount.
Tomorrow after work I'll give it another round and report back.
Sooo grateful.
โApr-07-2015 07:07 PM
