โSep-24-2018 04:20 PM
โSep-25-2018 05:26 AM
โSep-25-2018 04:50 AM
โSep-25-2018 04:48 AM
badsix wrote:Dutch_12078 wrote:
What's happening when the shower head valve is shut off is the cold water is pushing the hot water back in the line so when the valve opens you get a cold blast first. I installed check valves on our shower hot and cold lines at the faucet inlets to prevent the back feeding when the shower head valve is shut off. Problem solved...
AWESOME I'm going to look into this.
โSep-25-2018 04:47 AM
badsix wrote:I wouldn't do that if you live in areas of freezing weather. But that's just me.Dutch_12078 wrote:
โSep-25-2018 04:42 AM
Addy15 wrote:
We have the opposite situation. It blasts out scalding hot when turning the shower head valve back on...ouch...stand back...
โSep-25-2018 03:46 AM
โSep-24-2018 08:53 PM
โSep-24-2018 08:47 PM
doxiemom11 wrote:
Ours does that too unless ------ start out with the hot water faucet turned all the way on - let the water get HOT, then slowly add cold into it until you have the right temp. We were turning both hot and cold on about half-way like we would in the house and that didn't work. Try this and see if it helps.
โSep-24-2018 08:45 PM
Boomerweps wrote:
Supposedly that's what the center hole continuing to shoot water out of when you use the water saver shutoff on the Oxygenics shower head prevents. By have a small continuous water flow, the temperature stays the same.
โSep-24-2018 08:08 PM
โSep-24-2018 06:35 PM
โSep-24-2018 06:18 PM
โSep-24-2018 05:49 PM
โSep-24-2018 05:43 PM
DutchmenSport wrote:
If your's is the original shower head that came with your camper, then "yes", that is just the way it is. You can always replace the shower head, even those on the end of a hose with any household conventional shower head or shower hose with head. The pipe threading is 1/2 inch, same as any household shower head or hand held shower wand.
You could even attach one of these and then you'd never have to worry about cold first, then warm....
โSep-24-2018 05:40 PM
