โSep-15-2018 03:39 PM
โSep-19-2018 08:12 PM
Ralph Cramden wrote:blt2ski wrote:
Sheep dip folks,
Some of you have obviously NOT been at any of the ski area's here in the NW US! Over 100 units on any given weekend at some places. NONE of them are winterized! I drained everything in the spring, refilled with water come Thankgiving to spend weekends at the local area. It got down to 10F many times, 20-25F max during the day for a weekend, ie friday pm to sunday pm!
ANy way, for the temps the OP is in, keep the heat going, inside lines will be fine! If you are going to be in sub freezing temps a lot as I was, get rid of any drains mid stream in the main lines, as water will freeze up and you will not have water beyond this point! Their are some other things one can do to make things better per say.....Unless you are going to be someplace as noted, below for a day or three or more, get some 2-3' of snow on the rig over those 2-4 days......you are worrying about nothing!
Marty
Not really sheep dip..............Just because you can spend a weekend in sub freezing temps with rig A which has all the water lines and fresh water tank inside the box, that may not be a great idea in rig B which has a tank under the trailer, may or may not have an underliner, and may have exposed water lines or uninsulated lines that are just laying on a sheet of coroplast.
You can freeze pex solid and not hurt it a bit, but you'll most likely crack every single fitting if they happen to be the plastic ones typically used in RV's.
โSep-19-2018 08:07 AM
โSep-19-2018 02:28 AM
blt2ski wrote:
Sheep dip folks,
Marty
โSep-18-2018 09:36 PM
โSep-17-2018 07:18 AM
โSep-17-2018 06:28 AM
dockmasterdave wrote:
How cold does it have to be or for how long, before I need to "winterize"....I was thinking even low 20's would be OK if it warmed up during the day.
โSep-17-2018 06:10 AM
โSep-16-2018 04:56 PM
Bumpyroad wrote:dockmasterdave wrote:
Thank you for all the answers. It would only be for a few days in North FL or close to there.
Never considered using the pink stuff, and not being able to use my water after that.
I only considered draining lines, maybe blowing them out. I can't imagine that a few degrees below 32 for a few hours at night, will freeze pipes in the walls with heat on, but I could be wrong.
As for whether or not the TT is prepped, I have never looked. Never had any need.
We are in south east Naples, so in 35 years of living here, I have only seen frost a few times, never a freeze.
Thanks again for all the good answers.
20 degrees is a long ways from a few degrees below 32.
bumpy
โSep-16-2018 11:44 AM
โSep-16-2018 08:23 AM
โSep-16-2018 08:16 AM
โSep-16-2018 08:13 AM
โSep-16-2018 08:09 AM
โSep-16-2018 04:31 AM
