How to unlock steering wheel with push button start?
767jetlag
I just purchased a Jeep Cherokee Trailhawk to flat tow. It has a key fob and pushbutton start. With a keyless system, does anyone know how to unlock the steering wheel for flat towing? Does it even need to be unlocked after you complete the steps to setup the transmission for flat towing? Thanks in advance!
7 REPLIES 7
et2
Have the same car. There isn't a steering wheel lock. The wheels follow the MH when in park ( after securing it in neutral ) and key completely off. Thus - no need to have the power on draining your battery unlike some of the other popular toads.
Securing it in neutral is in the manual. It's very simple to understand and easy to do.
767jetlag
Thanks everyone - good (and helpful) info. - much appreciated!
I'm just getting started with this RV life. Just about everything is new to me - looking forward to a great summer!
dubdub07
There hasn't been a lock on a Jeep since 2009.
2013 Fleetwood Discovery 40G
TOADS: 12 Jeep JKUR Wrangler, 16 Cherokee Trailhawk, 15 Grand Cherokee, 13 RAM 1500 Longhorn (not a toad) American STEEL = American profits
RET USAF MSGT (26yrs) and still DoD ATC.
DW,DS,DD in the MH w/Westley the killer PUG!
D_E_Bishop
Hey jetlag, try following the owners manual for setup and then try to turn the wheel. I bet docj is correct and that there is no lock. A corolla we rend a while ago had the pb start and younever tool the key out of your pocket.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
docj
Why are you assuming the car has a steering wheel lock? Not all cars have them; they are not required by law. Page 124 of your owner's manual doesn't discuss anything other than how to put the transfer case into neutral. Presumably that's all you have to worry about.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/braking system
WiFiRanger Ambassador/RVParkReviews administrator
Follow our adventures on Facebook at Weiss Travels
767jetlag
Ok, well that's the first place I looked! Thanks anyway.
SpiKar
Should be in the owners manual.
