Jun-13-2019 12:57 PM
Jun-17-2019 04:01 PM
Eric&Lisa wrote:BillyBob Jim wrote:
Put up a fence facing the busy bodies, but get a permit for it LOL.
Oh, that is a good one! A slow burner. Took me a minute. Of course, that baits a question.... Yours??
Jun-17-2019 03:35 PM
Jun-17-2019 01:57 PM
Eric&Lisa wrote:
And nosy neighbors... Hehehe, I would dig & refill holes in my yard. Maybe scatter a few pieces of PVC around. Add a wheelbarrow or shovel for flair. And just see which busy body makes a big deal.
-Eric
Jun-17-2019 01:53 PM
WTP-GC wrote:
...Plus, you got nosey neighbors that stroll by and see a shovel in the dirt, and that's enough for them to call the building department or HOA....
Jun-17-2019 12:49 PM
WTP-GC wrote:Cummins12V98 wrote:WTP-GC wrote:Cummins12V98 wrote:
I have literally 125' of 3" pipe from my threaded opening to septic tank and I dump 100 gallons or more at a time FULL BORE at my RV pad with several years of Summer use with ZERO issues.
^^Exactly
A properly functioning septic tank is always full of water up to the bottom of the drain field piping. The drain field consists of no less than 3" pipe, and if it's a traditional system, probably multiple runs of 3" pipe between 100 and 200 lineal feet. 100 feet of 3" pipe will hold about 30 gallons. If the drain field is percolating correctly, you will have no issue at all.
My comment was directed at how well the 3” drain pipe works for my RV dump.
My drain field is all perforated 4” pipe.
I understood your comment, and I was adding commentary to confirm it.
Jun-17-2019 12:33 PM
Eric&Lisa wrote:
And pulling a permit?? Are you kidding me? To put in a Y-fitting, a few feet of pipe, some couplers, and a screw down plug? Just do it and be done. The 'poop gods' (as they are known in my county) only care about adding capacity (more toilets) to an existing system. An RV has temporary capacity that is typically only used when the home systems are not being used. Therefore it is a zero sum game. No additional materials are going in the system that wouldn't be provided should you have stayed at home instead.
-Eric
Jun-17-2019 12:23 PM
^^Exactly
Dumping 100 gallons thru a 3 inch pipe would take a little longer than if the pipe was 4 inches. But what happens when that 3 inch stream hits the tank? A 100 feet of 4 inch pipe will be half full of what was the top water of the tank. Around here, this year, that could make a yard look like a spring.
Jun-17-2019 10:17 AM
Eric&Lisa wrote:WTP-GC wrote:
OP, as a contractor, I would not like that you hired me to do a job and then went onto a random Internet forum to verify the quality of my work or choice of materials. If you came to me (the professional) and told me that a faceless, nameless internet somebody said that I was doing it wrong and suggested a better way of doing it, I'd walk off the job. The nature of questions you're asking suggests that you don't know anything about the work taking place, so be mindful of that when you offer advice to your contractor. There's an old saying...if you can't dazzle them with your brilliance, then baffle them with your BS. It would in your best interest to let the contractor do their job without telling them how it should be done...in this case.
Nicely written, and a good point made. However....
Within the ranks of any demographic, 10% of the people are simply jerks. Contractors are no exception. It is wise for anyone engaging any services to educate themselves. This is not to throw it back and say "The Internet says do it this way". This is to be able to validate that they got the good contractor in the 90% ranks, and not the 1 in 10 that are jerks. A jerk, in any profession, will straighten up when they learn that the mark (errr, the customer) knows a thing or two about the situation.
In my opinion, part of the contractor's job is to explain they 'why' behind what they did. The contractor should be able to say something like "Yes, the Internet says to use black PVC, but in XYZ county we are approved to use white PVC, and here is the specific code regulation." I know I am working with someone who knows their stuff and is willing to stand behind the decisions they made.
More communication with the contractor and more education by the customer avoids distrust and dissatisfaction later. I would avoid a contractor who is afraid to take my questions and unwilling to defend their decisions. You wouldn't need to walk off the job as you would have already been thrown out for taking such an arrogant and condescending approach towards the customer.
Oh goodness, I got derailed and didn't address the OP's topic! I put in a RV dump in. I matched the pipe I already had for size, color, etc. I gave it a gentle slope. Some hacksaw here, some glue there, and it works just fine. Don't overthink it. Make it look like everything else and remember that gravity will move the 'stuff' where it needs to go.
-Eric
Jun-17-2019 10:06 AM
^^Exactly
Jun-17-2019 04:56 AM
^^Exactly
Jun-17-2019 12:26 AM
Jun-16-2019 08:44 PM
^^Exactly
Jun-16-2019 12:21 PM
Jun-16-2019 10:39 AM
