โOct-17-2013 02:33 PM
โOct-18-2013 07:43 PM
stripit wrote:
My tires are under my slide outs and one tire didn't blow but list the tread and caused damage to the bottom of the slide and the areas behind. As we were repairing the damage I figured had I had a shield above the tires that extended beyond where the tires could damage with a tire tread failure again that would stop much of the damage. So I went to the local heating and A/C shop that made sheet metal duct work to cut and bend me the sheets I needed. They had various thicknesses of metal and I chose the thickest and had it bent to fit exactly where I want it to go. About a dozen self taping screws per side and I'm kind of bullet proof now should it ever happen again. The use of a tire pressure monitor system is something I strongly recommend but if the tire just peels a tread without losing any pressure it won't show, but that is a rare occurrence. Normal tire failures are related to low tire pressures. I think my metal shields cost about 20 bucks each as I recall.
โOct-18-2013 07:18 PM
โOct-18-2013 06:24 PM
โOct-18-2013 06:03 PM
cdlaine wrote:
Thanks for all the insights... good conversation.
Am I incorrect in thinking that using the spray in
bed-liner stuff within the wheel well and the immediate
surrounding area (impact zone for shred) would not be
reasonable ? On my prior truck I had the stuff in the
bed and it was bullet proof for ten years.... thoughts ?
Charles
โOct-18-2013 04:56 PM
โOct-18-2013 04:46 PM
Charles
โOct-18-2013 03:37 PM
โOct-18-2013 01:22 PM
cdlaine wrote:
So, as I gather from reading the variety of posts on the forum...
tire blows, tire shreads, $100's - 1000's dollars in damage...
โOct-18-2013 12:47 PM
Me Again wrote:parkmanaa wrote:
IMHO 'ME AGAIN' has the best answer above. The Michelin XPS all-steel cord tire is undoubtedly the best commercial tire on the market. That tire has been around at least 15 years and I have yet to see or hear of a single complaint (some complain about the initial price, but ................)
I was in the tire industry for 40 years, did many scrap tire analysis, and questioning of persons who had tire failures. Most is classified in this order:
- cheap tires to begin with, or tires too small or low load-rated.
- poor maintenance of air pressure.
- overloading, usually having no idea what their rig really weighs loaded.
- Impact damage, i.e., hitting something in the road, holding your breath for a
few miles, then breathing again 'because I didn't ruin a tire'. Well, guess
what, you really did, sometimes it takes a few hundred miles to actually blow.
- failure to have tires inspected by a qualified tire technician beginning in
their 5th or 6th year.
- Lastly, tire age. Don't be snowed into thinking tires will self-destruct
after 5 or 6 years. Properly maintained, they should last a good 10 years.
Could be more reasons, but these are the ones that come to mind; in that order.
Me Again here! I think you are in tune with where I am at. Some tires, which includes most of the currently available ST tires just do not have a good track record! The two tires I noted(and I have used both) have not had the negative feed back that so many other tires get. I was lucky in that my trailer came OEM with 16" LT tires as an upgrade to the standard 15 ST tires. However they were Kenda Klever china bombs! Kenda gave me 110 each to remove them from service in the first year before they failed, and I installed Michelin XPS RIB which I ran for 6.5 years and 40K+ miles, then sold them on CL for 200 bucks. I installed Bridgestone Duravis R250's this go around and have been to Arizona and back on them twice. The R250 may be a better tire than the RIB and cost about 50 bucks less per tire. Which played into my choice of them this go around.
So having LT from the get go, I was not caught up in the ST tire night mare that some have become stuck in. I wrote this about tires back in 2009 and I believe that it is still worth a read.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23161726/srt/pa/pging/1/page/1.cfm
This also is a good read! http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23225970/srt/pa/pging/1/page/1.cfm
Lets just say that the tire industry and the trailer industry is not doing consumers many favors by supplying cheap tires OEM on new RV trailers. An educated consumer should not agree to drive off the dealers lot on cheap tires or tires that are overrated and barely meet the GAWR requirement.
Chris
JJBIRISH wrote:Yeah, keep that tape on you crazy monkey! LOL, just kidding, I enjoy your posts. ๐
While a metal wheel well might be a good idea and not hurt anything or even help someโฆ a blown tire and the resulting damage of the tread failing around is a fairly violent eventโฆ the metal wheel well not attached substantially to something strong enough to hold it in place could be ripped loose causing even more and worse damageโฆ
OOPS, I forgotโฆ
โOct-18-2013 12:44 PM
โOct-18-2013 12:21 PM
โOct-18-2013 11:45 AM
โOct-18-2013 11:35 AM
Old-Biscuit wrote:lol I just added 1/8" diamond plate in the wheel wells to mitigate damage during the next tire failure.
Short of diamond plating the underside & skirting.......NO
โOct-18-2013 11:02 AM
