levelers
F450
Has anyone ever put levelers on their RV? Much work?
10 REPLIES 10
ItsyRV
I guess that depends on the type of RV you're talking about. Installing them on a Class A isn't the same as a Fifth-wheel.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
sayoung
I had the Equalizer hydraulic system added to my 5er but I took it to thier install shop in Elkhart. They do have some authorized installers across the country but none were close and good excuse for a road trip.
I did look at the Lippert & Bullfrog electric systems and you can drill frame & bolt on the brackets. At the time both of these only offered a 4 pt aftermarket unit but Bullfrog was supposedly going to also have a 6 pt . I could have installed any of the systems but the Equalizer labor price was so cheap it was a no brainer.
Now that I have a 6 pt hydraulic system, glad I didn't get the cheaper electric type.
Guy_Roan
I just took my Lippert electric ones off, so yes it would be a bear to intall new ones.
Guy
Home_Skillet
I installed the Big Foot jacks on my Class C.
Yes. Lots of work. Mounts have to be welded to the frame etc.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
PawPaw_n_Gram
Had a friend who put a 4-point Lippert system on a Mesa Ridge 5er once.
His comments on the installation process are not repeatable here, but said it was the best thing he ever did.
Unfortunately he passed in 2018, so I can't ask him details about the process.
He looked at my TT, and since my frame is covered by the underbelly material, to start I have to rip that all off to get to find proper mounting points. Also teh frame I-beams might not be tall enough to mouont.
After I got a system installed, I would have to build a new underbelly.
Of course I didn't do that.
Full-Time 2014 - ????
โ€œNot all who wander are lost.โ€
"You were supposed to turn back at the last street."
2012 Ram 2500 Mega Cab
2014 Flagstaff 832IKBS TT
beemerphile1
This is what came on mine but can be installed yourself.
https://www.etrailer.com/s.aspx?qry=Ground+Control+3.0
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
MrWizard
Moderator
Moderator
Much work ?
Yes ...
Lots of work to install leveling Jack's
Less work to install "self contained" Jack's, that only need electrical wiring run to each jack
Where there is no need to install hydraulic lines, pump etc..
I can explain it to you.
1997 F53 Bounder 36s
F450
ScottG wrote:
What exactly do you mean by "levelers"?
electric levelers you put on your RV to lever the coach
ScottG
