โDec-20-2014 04:28 AM
โDec-25-2014 03:36 AM
โDec-25-2014 03:26 AM
wca01 wrote:
The easiest tow bar to connect and disconnect is the Demco. Each tow bar arm is independently mounted. You only need to handle one at the time. Disconnecting is just the reverse, but also only one at the time.
You can completely connect one arm. Then connect the other one. There's almost no weight at all. There's really nothing on the market that offers such easy connecting and disconnecting. I've used most all of them!
Good Luck!
Wil
โDec-24-2014 03:48 PM
โDec-22-2014 10:55 PM
dahkota wrote:F1bNorm wrote:
I think I have the same problem. Because one arm is setting on the ground and the other you're trying to attach is at too great an angle. I have an easy solution. I have a cheap HF tote that has a rigid handle. I set one arm on the tote while attaching the other. Makes it easy. The tote I use for storing the wiring harness, safety cable, spare pins and a pair of work gloves. Before the tote I used a small step stool and then the cardboard box I use for the accessories.
Norm
Thanks Norm! While I don't know what an HF tote is, I think I get the idea. I've tried resting the 'other' arm on my bumper but always manage to knock it off. I will try with a large box I have - it will probably save me quite a few bruises!
Now, if you have a hint for the pin that won't come out...
โDec-22-2014 10:34 PM
โDec-21-2014 02:49 PM
โDec-21-2014 11:36 AM
dahkota wrote:
.... If you are off a little bit, it is a struggle to do it alone as the arms are awkward. Being 5'6" tall, my reach isn't as long as others which may cause some of the awkwardness. I think the arms of any tow bar would also be awkward, but I have no experience with them.
โDec-20-2014 07:35 PM
โDec-20-2014 11:54 AM
Norm
โDec-20-2014 09:53 AM
โDec-20-2014 09:26 AM
Norm
โDec-20-2014 09:04 AM
dahkota wrote:
We have the ready brute elite. While I have no problems carrying it, hooking it up alone is another matter. If you are very close to perfectly aligned, you can hook one side then the other. If you are off a little bit, it is a struggle to do it alone as the arms are awkward. ---snip---
โDec-20-2014 07:25 AM
โDec-20-2014 06:56 AM
