Looking for a grill
TEO
I've done a search on grills, but didn't find the answers I'm looking for. We want to get a grill to carry in the motorhome that is relatively portable, but able to set up semi-permanently and run off the LP tank of the coach. There is already a quick connect fitting and valve in the LP system downstream of the regulator, so I'm looking for a grill that will run on the low pressure gas and not directly from a 20 lb gas tank.
Thanks,
Paul
Paul & Helen
2002 Winnebago Journey DL:)
1999 Jeep Cherokee toad :C
Yellow Lab, Jodie, Chocolate Lab, Coco :B, and Lab/Golden mix, Sandy.:B
FMCA 98905
http://ptempesta.blogspot.com
16 REPLIES 16
deleted-2
Welp I guess it's time for me to bite down and get the Q 100 and an RVQ hose.
I had forgotten our coach had the quick disconnect until I noticed it yesterday.
Of course the DW said "you didn't know that was there?...remember the walk thru the guy pointed it out!"
Yes dear...
cherrykiss3
I have the Weber Q 100 and love it! Even I can move it around.
Cherry
joelabq
I have a Weber Q120. I took off the regulator and installed a quick connect for use where the standard (junky) RVQ was. If you have an RVQ laying around, use the quick connect from that if it came with one. Works great!
2020 Chevy Duramax 2500
2013 Wildcat 312bhx-ok
frankdamp
We have a Weber Q-220 and love it. It's a bit heavy if you try carrying it with the cast-iron grill plate still inside. I didn't like the idea of a long flex hose with full tank pressure in it. I'd also heard that some folks have had problems with the sensitivity of a whole-rig sized regulator when only using small flow rates for the grill.
I didn't want to haul a big 20-lb tank either. I solved the issue by getting a "squatty" 10-lb tank that has the same base ring size as a 20-pounder. I got a "stabilizing base ring" at Camping World and bolted it to the floor of an outside stow-bin. The tank is a very snug fit and doesn't seem to need additional tie-downs.
The only snag with the Q-220 is that it's about 3/4" too tall to put in the stow-bins of our MH, so I have to take the lid off every time I put the grill away. Not a big deal, with the hinge pins it has. We will be getting the fold-up cart for it before our next trip as we found a couple of CG's that wouldn't allow grills on the picnic table.
Frank Damp, DW - Eileen, pet - female Labrador (10 yrs old), location Anacortes, WA, retired RVers (since Dec 2014)
frankdamp
sportsman_500
Thanks everyone for the replies. I will check into the kit.
Ron3rd
sportsman 500 wrote:
Others have made the same mod to a Coleman Roadtrip Grill. I've been using a Roadtrip since 2002, off of an Extend-a-Stay fitting. Just this year, I've had to replace the grill grates due to wear. The grill continues to function flawlessly. I have one of the heavier duty (blue) Roadtrip, not the red LXE version.
I am looking to do the same to my Roadtrip. Can I ask? What is an "Extend-a-Stay fitting"??
If you taking high pressure off your tanks, what you actually want is the Extend-A-Flow kit, not the Extend-A-Stay; two very different setups. The Extend A Flow has the Tee that installs to your tank, and then you attach the hose. Used one for about 9 years with my Weber Q and gave it away when I sold the trailer.
Extend-A-Flow Kit
Equilizer Hitch
Honda EU2000
Latner
CincyGus
Another vote for weberQ in whatever size you like. 100 here, some like the larger 200 series. All aluminum except the grate, rounded bottom makes a quick wipeout after it cool easy to store clean, disposable/replaceable drip tray liners, accessories at most big box stores made it a no brainer for me. Easily modifable to run off bulk tanks (hose), 1 lb tanks as it is, or low pressure with the proper Quick Connect adaptors make it one of, if not THE most popular grill for RVers.
2015 GMC 2500 Denali Crewcab 4x4
2019 Forest River Wolfpack 23pack15
Hope your travels are safe and the friendships made camping are lasting.
sportsman_500
barth
I have the Cuisinart Grill. Bought with on Amazon $149. Just love it
Fire_Instructor
therink wrote:
I have a Weber Q220. It is a great grill. Best I have ever had. Going on 4 yrs now and not a sign of rust. I recently adapted it to the low pressure quick connect on my fiver. I bought a 10' quick connect hose and male QC adapter for the Weber online for about $50. All I had to do was remove the regulator on the Weber. It works great. The grill actually works better off of the rv's low pressure system than with the Weber regulator.
Steve.
Fire Instructor
2022 Coachmen Leprechaun 319MB
therink
Steve.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
lap527
OnaQuest wrote:
lap527 wrote:
sounds like a weber baby q 100 might be on your list to check out.
The Weber Q requires the high pressure connection. Install an Extend-A-Stay adapter and hook your Grill to that. Works perfectly.
...and that be a oops...or too many glasses of wine...sorry!
2006 Dodge 3500 dually 4X4 / 2013 Livin Lite 10.0 TC /Torklift talons, fastguns, stableloads, superhitch, and truss/ towing a
14'V Nose Trailer when needed.
