low water pressure at CG
0rion
We woke up this morning with no water pressure. Pretty sure it's on the camper side. The CG doesnt have a ton of pressure but there's enough flowing from the hose that our camper should have it. Either a clog or a bad air valve maybe???? Best way to trouble shoot it? I dont have an air compressor to blow back through the lines. I also notice on the inlet where city water connects there's a little plunger in that fitting. I worked that in & out with my finger & it seems to be working normally. Suggestions and ideas welcomed.
11 REPLIES 11
0rion
Got pressure back for the time being. Worked that backflow spring in and out several times & have pressure now. I left the tank full just in case. I'll replace that valve when i get back
down_home
You have to use filters, especially for sediments and nasties to protect your plumbing. Many many times we find ourselves, especially at holidays, with parks jammed, low water pressure. We fill the tank at night and use the water pump for regular use.
You can just turn the pump on on ours while connected but you later have to flip the valve to refill the tank.
TyroneandGladys
If you do not have water at pressure at the faucet outside contact the campground why should you do there work for them.
Tyrone & Gladys
27' 1986 Coachmen
Old-Biscuit
That city water inlet check valve is a cheap plastic plunger/spring/o-ring assembly.
Even though it moves in/out freely doesn't mean that the o-ring is in proper position..they can get dislodged and block/restrict flow.
If you have good water flow thru hose with and without the regulator...then it's that cheap plastic check valve causing your low flow problem.
You can remove the check valve internals to get good flow back. then replace city water inlet assembly later OR use a 3/4" pvc plug to cap it off.
The check valve is just there to 'seal' city water inlet when using on-board pump.
I installed a 90* elbow with a garden hose shut off valve on mine years ago.
Hook up hose and open valve when I use city water or leave valve closed when I use on-board pump
Have same set up on black tank flush connection.
DavidP
0rion wrote:
Using fresh water tank now and pressure is good. Tried with & without pressure regulator & still no flow in the camper. 99% sure it's on the camper side. The backflow check valve moves in and out easily. It almost has to be in that check valve though right?
Sounds like the check valve on the inlet since you have good pressure with the demand pump. I would also make sure it is not the CG water. You may have good flow with the CG water but the pressure might be very low and once there is a restriction it drops even lower. Has this happened at other CG's?
gcloss
HappyKayakers wrote:
Do you also use an inline filter? Those get clogged sometimes, especially the cheap blue ones. One other possibility is screen washers - they can get clogged with sediment.
Two weeks ago the water stopped flowing from my kitchen sink. I had water from the bathroom sink and tub. First thought something happened to the faucet. Turns out the aerator screen in the outlet of the faucet was completely clogged.
2012 Ram 2500 Big Horn Crew Cab 8' box
5.7 Hemi, 4x4, 4.10
2015 Jayco Eagle 284BHBE
0rion
JEBar
unhook your hose and see (roughly) how long it takes water coming out of the tap to fill a container .... then reattach the hose to the tap and disconnect it from the camper .... turn on the water and see if it takes roughly the same time to fill the container .... if it does, the problem is most likely in the camper with the backflow valve and/or screen washer at the camper's water connection being the prime suspect .... if it takes markedly longer, the pressure regulator, filter, and or a hidden kink in the hose are the prime suspects .... as has been noted, to get by until the problem is taken care of, using the camper's fresh water tank and pump is a good alternative
Jim
'07 Freightliner Sportchassis
'06 SunnyBrook 34BWKS
HappyKayakers
Joe, Mary and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
DavidP
Did you try without a regulator to see what happens? I would also add water to the fresh water tank and try with the demand pump and see if you have good pressure. If so there are only a couple things it could be.
Road_Runners
We have this problem a lot. When the pressure gets too low we resort to turning on our fresh water pump and drawing water from our onboard water tank.
'05' F-250 Power Stroke
'00' 30' Cameo Fifth Wheel
