โSep-07-2019 12:28 PM
โSep-08-2019 10:53 AM
smsinville wrote:
old-biscuit ... thanks for the quick reply. I have tested the current on both ends of the gas valve and it is within spec. So, it has current, yet no gas. Would you then assume that the gas valve is defective? If it is defective would that mean no spark is being sent? Thanks.
โSep-08-2019 04:07 AM
โSep-08-2019 03:53 AM
โSep-07-2019 08:35 PM
smsinville wrote:
The model is supposedly "german": RML8555. The components of the system don't match old-biscuit's diagram. (Although I've had other RV's that essentially match that layout.) It's an unusual system. The only "test port" is actually BEFORE any other components. It appears not to have a solenoid. There is a "gas control valve". ajriding ... I'll try what you suggested tomorrow. I have confirmed that there is 12 volts coming to the system. The fridge is a 3-way, and it works well on both 110 and 12v.
โSep-07-2019 05:54 PM
โSep-07-2019 03:24 PM
smsinville wrote:
I've been trying to troubleshoot why my refrigerator does not work on propane: no spark, no flame. In order to test the propane, I removed the test port plug in the propane supply line at the fridge outside panel, and connected a water column manometer. When I turn open the propane valve, the gas comes into the manometer and just gurgles right through! Should I assume this means that the gas pressure to the fridge is too high (supposed to be 11 inches on manometer)? The stove burners work fine, and the propane funace works fine.
โSep-07-2019 01:32 PM
Bud
USAF Retired
Pace Arrow
โSep-07-2019 01:11 PM
โSep-07-2019 12:54 PM
