LP Gas pressure at refrigerator
smsinville
I've been trying to troubleshoot why my refrigerator does not work on propane: no spark, no flame. In order to test the propane, I removed the test port plug in the propane supply line at the fridge outside panel, and connected a water column manometer. When I turn open the propane valve, the gas comes into the manometer and just gurgles right through! Should I assume this means that the gas pressure to the fridge is too high (supposed to be 11 inches on manometer)? The stove burners work fine, and the propane funace works fine.
9 REPLIES 9
Old-Biscuit
smsinville wrote:
old-biscuit ... thanks for the quick reply. I have tested the current on both ends of the gas valve and it is within spec. So, it has current, yet no gas. Would you then assume that the gas valve is defective? If it is defective would that mean no spark is being sent? Thanks.
DId you test the Burner Control Module.....?
That module supplies the Current for Spark ELectrode
Scottiemom
Since you're in Ohio, why not take a little side trip over to Shipshewana and see Leon at National Refrigeration. Nobody better at troubleshooting and fixing RV refrigerators than Leon. And he works much cheaper than the RV businesses.
He can tell you exactly what's happening and can fix it for you. He's a young Amish man, so you can call and leave a message. He gets to his messages usually during his lunch break. But he WILL call you back. Make an appointment and he will fix you up. We were just there a few weeks ago. Fridge working, but the ARP unit was shutting it off, which is what it does, but it was happening for longer periods of time. Turns out a sensor was bad. He replaced it for $50. $25 part/$25 labor.
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
Traveling with Brendon, my Scottish Terrier
2022 Honda Odyssey
2011 Mazda Miata MX-5
2021 Coach House Platinum III 250DT
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
smsinville
Old-Biscuit
smsinville wrote:
The model is supposedly "german": RML8555. The components of the system don't match old-biscuit's diagram. (Although I've had other RV's that essentially match that layout.) It's an unusual system. The only "test port" is actually BEFORE any other components. It appears not to have a solenoid. There is a "gas control valve". ajriding ... I'll try what you suggested tomorrow. I have confirmed that there is 12 volts coming to the system. The fridge is a 3-way, and it works well on both 110 and 12v.
YES that is a totally different control scheme
It is a Dometic 8 Series (RML8555)
Gas Valves are dual serial gas modules that use Very Low Voltage (less then 1.5V)
Each valve has a test point to measure voltage and resistance (28.5 ohms)
See pg 47
Burner Control Module provides Igntion source and flame proving signal (separate spark electrode & flame ionization probe)
Also has Test points for measuring voltage
See pg 48
Service Manual
smsinville
Old-Biscuit
You have couple of issues:
No Spark/No FLame
Circuit Board sends 12VDC to gas valve and spark electrode at same time
Gas valve TEST port is downstream of gas valve/solenoid so it must be opening if you have gas flow thru manometer.
No Spark......
Circuit board sends 12VDC from transformer to electrode when gas valve is opening.
Spark gap too narrow/too wide ---no spark (1/8" - 3/16") centered directly over burner slots
Electrode wire connection clean/tight at transformer
Manometer....tubing in 'U' shape. One end Open/other end connected to gas test port. Water in tubing.
11" WC is only 0.4 psi so it should NOT gurgle THRU
enblethen
Make and model of refer?
Check connections to the eye brow.
Is the refer set to auto or LP?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
sayoung
If it's not sparking, check for 12 volts to the unit.
ajriding
Well, if you have no spark, then start there. No spark = no flame. No flame = no work.
Try a long grill lighter and see if you can hold a lighter flame under the thermocouple where the flame should be (the fridge should be on the gas setting and set to run). I would not think you need to hold in the button since you are lighting it yourself like this.
The propane unit has a sensor (thermocouple) that senses heat (flame) and will shut off gas flow if there is no flame/heat. The "push button in while lighting" is the over-ride for this.
