โJan-15-2016 09:41 AM
โJan-31-2016 07:51 AM
โJan-30-2016 07:34 PM
โJan-15-2016 01:09 PM
โJan-15-2016 01:02 PM
BB_TX wrote:
Also look on the driver's door sticker to see what the max payload rating is. There should be a statement something like "Do not load in excess of ____ lbs".
โJan-15-2016 12:57 PM
โJan-15-2016 12:43 PM
โJan-15-2016 12:40 PM
โJan-15-2016 12:05 PM
โJan-15-2016 11:45 AM
โJan-15-2016 10:27 AM
โJan-15-2016 09:46 AM
BenK wrote:borninblue wrote:
snip...
OK got little lost, there. The wife and I combined are about 350lbs, plus two small children. So I can load up how much in the bed? Man all these numbers minus this and that I am lost.
This quote below might help you see where on the food chain of ratings
down to pavement is whatever they are talking about
A generic graphical representation of how the ratings system and
the components that make up that system looks likeBenK wrote:
Hi Chad and WELCOME !!!
Lots to talk about and learn (everyone can learn something on this
topic)
Careful on what sales folks tell you...they are in it for their paycheck
Some know, some don't have a clue on the needed specifications and
how that system works (ratings system)
First, decide if you believe in the OEM ratings system or not.
If not, then do whatever and this discussion academic. Note that you
will then assume both the warranty and liability of the vehicle
If yes, then read up and hope my quote below will help you 'see' the
big picture. Most advice's have no skin in the game...so read up on
their old posts to see if they have similar values you do
Too many take any 'one' component in the 'system' as the basis for
their decision and/or advice. It is s WHOLE SYSTEM made up of components
and sub-systems. Again the diagram will show the inter-relationships
Then the MTWR (max tow weight rating)...the OEMs use a flat bed trailer
with almost no side/frontal area. That trailer is loaded with blocks
of concrete/etc and placed best to derive the highest MTWR...plus they
play it to have a 10% tongue weight...that provides the highest MTWR,
but few trailers actually have a 10% loaded tongue.
Higher tongue weight percentages tow better...on average or general rule
Good luck and keep posting on this thread to that other newbies can
learn from your experience
Ben
PS...used that 3 wheeled motor cycle to add a bit of whimsy and to
show that anything can tow just about anything...just how well is
the crucial point
Below quote from this thread: Where can I find GCWR?BenK wrote:
Posted: 10/09/15 09:25pm
This quote from this thread might help you visualize how the system
looks like in graphical form
Contradicting Tow Vehicle AdviseBenK wrote:
Posted: 08/22/15 12:19pm
Welcome to both this forum and the world of RV'ing
Many times, salesman are not lying per say, but out of context in most all
cases.
Ditto advice on any of these freebie forums...it is worth the price paid. Also
learn to filter the advice to your needs and opinions. Many forget that newbies
do NOT have the experience and hard knock schooling to filter well...those
'sure you can'...'have been doing it for decades'...etc
I do NOT advise in that regard, but try to provide information
that the Newbie must find, weight and do the simple math for their
own Risk Management Decision (AKA...gambling)
First decide if you believe in the OEM ratings system and numbers...or not
If not, then academic and do whatever, but know you have taken the OEM(s)
off the warranty and liability hook and now own them...
The generic formula is:GCWR => TV + Trailer + everything loaded
This has the OEM dialed in safety margins for longevity, safety
and to agency mandated MINIMUM performance...biggie for me is
braking the whole setup
Of course best to actually weigh everything, ready to go RV'ing,
axle by axle
Gather the information for both TV and Trailer: GVWR, F/R GAWR,
GCWR. Tongue percentage weight of ACTUAL weight is also needed
You will find that the MTWR (Max Tow Weight Rating) is bogus, unless
you have the stripper TV and 'dry' trailer that has a 10% tongue
weight percentage (it should be 12% to 15% and I prefer heavier)
Here is the graphical representation of how the ratings systems
looks like, or works. A bit of whimsy and mean it...anything 'can'
tow, but how well, how long and how safely is my goal...for a half
ton 'can' tow the Space Shuttle...but for how long...how well and
how safely???
howmuchcanitow howmuchshoulditow
