Need Help With Determining Weight Numbers
navajochief
Truck and Trailer together: 21,540 lbs
Truck only: With Hitch attached: 8,060 lbs (GVWR) 11,400 lbs
Trailer at rear axles: 10,240 lbs
Front GAWR: 5,700 lbs
Rear GAWR: 7,000 lbs
I wasn't able to get the vendor to weigh my axles individually and/or my hitch weight as well.
So this is what I got on my own:
Hitch wt: 3,240 lbs
Total wt of trailer: 13,480 lbs
Is my math right?
I weighed myself at a public truck scale in town that told me they weren't able to help me with weighing my hitch weight and axle weights individually. I plan to go to our local CAT scale the next time for comparison. However, with the numbers I was able to get this is what I got for my hitch weight and total trailer weight.
Thank you.
Mark
'05 F350 SRW 6.0, FX 4x4 CC/SB 4.5" Donahoe Racing Lift, Dick Cepek Fun Country 35" tires, Helo 18" Wheels, Dieselsite Coolant filter with ELC, OEM 4.30 gears, Air lift 5k bags, Pullrite 18K ISR Superglide hitch, Edge CTS monitor.
2016 Keystone Fuzion 325
13 REPLIES 13
IDoMyOwnStunts
ACZL wrote:
So it's a gas motor. 2wd or 4x4? Trk GVW is around 11,200 +/-, Max combo is 23K Am I right? From what I see w/ your numbers, looks like you are around of trk GVW. CAT scale will tell you for sure exact axle weights for all axles.
No. It's a Ford 6.0, therefore it's a diesel.
I'm done. This isn't a place to be helpful. It's a place where curmudgeons with a superiority complex will nit pick everything. If you want help, go elsewhere. Admin, delete my account please.
navajochief
Tires are Load E and rated to 3750 lbs each at 65 psi.
2005 Ford F350 SRW 6.0 PSD, CC, SB 4.5" Donahoe Racing Lift, Dick Cepek Fun Country 35" tires, Helo 18" Wheels, Dieselsite Coolant filter with ELC, OEM 4.30 gears, Air lift 5k bags, Pullrite 18K ISR Superglide hitch, 5k HID headlights, Edge CTS monitor.
Cummins12V98
What is the load range on your 35's and what is the max carrying capacity? If D's you most likely will have a very bouncy ride and potential tire failure.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
navajochief
It weighed empty with no water and no fuel. I do not have toys (UTV/ATV) I do not plan to purchase or have. I have a jeep that my wife drives to our local off road area. I am only 5-6 miles from Superstition Mountains and 1/2 hr drive to Glamis. It's only my wife and I and our kids stay behind. I'll be carrying water weight and fuel weight along with whatever we pack (food, water). When I tow it for getaway trips I do so with no water or fuel. Only propane tanks full and whatever food and/or cargo we take which isn't much. When I posted this thread I did make sure the "append signature" box was checked! Don't know why it didn't transfer over.
ACZL
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
fj12ryder
^^^^^^^^Me too. I'm more than willing to help when I can, but I hate to have to dig for the facts. Want help, post all the pertinent info.
Howard and Peggy
"Don't Panic"
Cummins12V98
"Many members do post a signature, but will provide information in their profile."
I'm too lazy to look!
rhagfo
2005 Ford F-350 6.0 PSD SB CC 4x4 SRW (Stock)
4.5" Donahoe Racing Lift, Dick Cepek Fun Country Load "E" 35" tires, Helo 18" Wheels, Dieselsite Coolant filter with ELC, OEM 4.30 gears, Air lift 5k bags, K&N air intake, Spicer balljoints & U-joints, Pullrite 18K ISR Superglide hitch, 5k HID headlights, Edge CTS monitor.
2016 Keystone Fuzion 325 with Monster Package
fj12ryder
Is the toyhauler loaded? What do you plan on carrying? You're right at the edge of your GVWR but depending on what you load, the weight on the truck may not change much, if any.
Howard and Peggy
"Don't Panic"
navajochief
The trailer is a 2016 Fuzion 325 (5er)
My truck is an '05 F350 SRW, CC, SB, 4.30 gears.
ACZL
What tonnage truck?
fj12ryder
Looks right to me.
Total combined weight: 21,540
Trailer axles: 10,240
Truck: 8,060
Subtract unhitched truck, and trailer weight from the total weight leaves 3240 lbs. which is the weight that sits on the truck with the 5th wheel attached, i.e. hitch/pin weight.
FWIW that works out to 24 percent hitch weight, might be a bit high but don't know if this is a toyhauler or a standard 5th wheel or what.
Howard and Peggy
"Don't Panic"
Cummins12V98
Fill in your signature.
Bottom line what does your rear axle on the TV weigh hitched and fully loaded?
