New Coleman Travel Trailer AC issue
Ddevilman
So we bought a Coleman trailer less than a month ago. Our 1st stay in it, and there was no air blowing out of the ac vents. Cold air was being pushed through the "cold air shower", but not through the vents at all. It was extremely hot in the trailer. After calling tech support and the dealer, neither of which had any answers or help, I started digging into the issue myself. I found that there was insulation tape cover the entrances to the ducts. Peeled it off, and immediately everything was working great.
I don't know if that is a standard thing for shipping new rvs, or if someone screwed up. Anyone else ever encountered this?
6 REPLIES 6
myredracer
prichardson wrote:
Unfortunately poor installation is not that uncommon. On a unit I purchased last year (different manufacturer) I had to reseal all the register connections as they were all leaking into the attic area.
Same here. I re-sealed all the vents and it works waaay better. Part of the problem was the ceiling luan plywood was sagging so much that the vents weren't pushed into the duct. I had to use some long #6 screws into the rafters to pull the ceiling up enough.
Route_66_Travel
My TT is 2 years old with a 15k AC. It has never performed like I thought it should. By chance I found the video below. The divider in my AC was worse than the one in the video, plus the intake ducts had big gaps between the duct and roof, so a large percentage of cold air was going into the roof. After fixing the divider and leaks the improvement in my AC flow has been amazing. Today it hit 100 degrees here and the temp in the trailer was 74 degrees all day long.
Watch this:
AC Fix
prichardson
2012Coleman
Your lucky - my first TT was a Coleman, and the first night camping in the Florida summer, the AC shorted out and filled the TT with smoke. Turned out the installers just jammed wires into a ball and something shorted.
2018 RAM 3500 Big Horn CTD
1492
Moderator
Moderator
Lwiddis
Not me.
