I've checked most of this but not all (thanks for the quick replies!)
It's definitely plugged in to 120VAC right now (batt full) and everything else works fine, all the breakers are fine as well. I haven't actually pulled the cover and checked for power at the refer plug, but I'll do that tomorrow.
I'm pretty sure propane is fine, but I haven't pressed the propane button as I just got this thing and don't entirely trust it yet (I know, it's stupid - but if it's plugged in I just leave the gas button off.. can't hurt)
I'll check propane just out of curiosity, but again I didn't press the button so that's probably a different issue. I need the thing to be working on AC anyways.
๐It is level on all axis.
It seems strange to me that it takes about 5 minutes for the "check" light to illuminate. I feel like that's probably NOT a good sign if it's trying to run on AC.
Edit: FWIW after about 15 seconds of turning the switch ON again, I can hear a click or two in the back of the refer unit. Not sure if this is significant or not, but it appears to have power.
2016 Springdale Summerland 2570RL Arctic
2006 Land Rover LR3 V8 HSE | OE tow pkg & air suspension
