Norcold Refrig problem
rgh30
Had a bad flat tire recently and it tore out power that went to my Norcold refrigerator now it wonโ€™t work when plugged up to power but will work on gas. I noticed by pulling the outside panel off and getting behind refrigerator, I saw the plug from refrigerator going into a receptacle that currently has no power. I assume the cable that flat tire hit must have gone to this AC receptacle. Could I just take AC plug coming from refrigerator and plug it into a available recepticle outside of camper and that will restore my power back?
3 REPLIES 3
Gjac
Check to see if your refer outlet is GFI protected, It may just need to be reset.
PawPaw_n_Gram
You really need to get the receptacle fixed, or pull the circuit breaker to shut off power to that circuit.
Full-Time 2014 - ????
โ€œNot all who wander are lost.โ€
"You were supposed to turn back at the last street."
2012 Ram 2500 Mega Cab
2014 Flagstaff 832IKBS TT
rrupert
That should work assuming there are no other problems with the fridge. It would be good to check the wiring to the receptacle to make sure there isn't anything that can cause a short.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
