Now I'd like to know what interior caulk to use
tomseeley
OK, I got good advice on what exterior caulk to use and not to use. Thanks, all of you who weighed in on that one.
Now my DW has shown me a small gap in the joint between the bathroom sink and counter top.
So now I'd like to know if I could use plain interior "bath and tub" type sealant, that I could get at LHD--that's Lowe's Home Depot, in case you missed my use of that term in the first msg!
Or is there still a type of caulk or sealant I should NOT use inside the rig also?
Thx once again...
Tom
2009 GMC Sierra 2500HD Duramax/Allison
2008 Nash 26X
5 REPLIES 5
tomseeley
Hey, thanks, guys. I appreciate the help; esp so quickly. I gotta get this off my to-do list ASAP!
2008 Nash 26X
Silicone is fine for interior things like sinks and tubs.
Just don't put it outside anywhere!
2007 GMC 3500 dually ext. cab 4X4 LBZ Dmax/Allison - 2007 Pacific Coachworks Tango 306RLSS
RV Rebuild Website - Site launched Aug 22, 2021 - www.rv-rebuild.com
Bill___Kate
I always keep a tube of clear Lexel on hand for interior work. It is clear, so it blends with just about anything, holds up well, and is readily available at most hardware stores.
Bill & Kate - Stone Harbor, NJ
w/ Bailey (standard poodle) and Zeke (partipoodle)- both rescues
2018 Ford F-250 Super Duty Crew Cab w/ 6.2L gasser
2014 Forest River Wildcat 272RLX fifth wheel
Dandy_Dan
Depending on the color you could use colored silicon to try to color match. Or I have also seen a stick on quarter round made from a rubber/vinyl type product that will stick to the wall and counter top and cover the gap and make a waterproof seal. Good Luck and Happy Camping.
dan218b@tds.net
Dan and Lori Branson
Anna 1 and Lily( The new one)
Sarah-7/16 and Beau at the Rainbow bridge
2015 Ford SD350 Crew Cab Power Stroke
2009 Open Range 337RLS
Old Fella Rally Member
RV.Net Ohio Rally Member
robsouth
Basin, tub and tile caulk is fine for interior.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
