โNov-18-2016 07:27 PM
โNov-20-2016 10:12 AM
โNov-20-2016 07:45 AM
โNov-20-2016 05:46 AM
โNov-20-2016 04:58 AM
โNov-19-2016 11:17 PM
Boon Docker wrote:geeeze is it April already? Ok, just buy aquarium snails and let them stay thereDennis12 wrote:
Go to a pet store and buy an algae eater. You will have to buy a small one depending on the size of your piping. Also keep plenty of water in the lines until the algae eater gets full. You may have to buy another depending how thick the algae is in the lines and how long they are.
Make sure you get him out of the pipe before he eats too much or you will have a plugged line. Then put him in a bowl of fresh water for a couple weeks until he loses weight then back into the pipe again later.
โNov-19-2016 07:58 PM
โNov-19-2016 07:21 PM
โNov-19-2016 04:21 PM
โNov-19-2016 02:27 PM
โNov-19-2016 01:14 PM
โNov-19-2016 01:01 PM
โNov-19-2016 12:56 PM
Second Chance wrote:
Pink slime around tubs, sinks, etc., is not a fungus, mold or algae - it's a strain of airborne bacteria known as Serratia marcescens. Since it is airborne, it's not a "clean to cure" situation but rather "clean to control" and must be done periodically. Since the OP is talking about inside water lines, I'm not sure if it's the same organism. Either vinegar or chlorine bleach solutions will take care of the situation.
Rob
โNov-19-2016 11:03 AM
โNov-19-2016 10:35 AM
