Please explain in very simple terms
GeeGee2
My husband and I both use CPAP machines. We would like to be able to boondock one night if we needed to while traveling. We have a 2015 Passport 23RB Elite. Are we equipped to boondock? Due to my husbands brain surgery we have to keep it simple and easy to accomplish. Can someone help me with this?
21 REPLIES 21
Johno02
Also 20+ years. Have used CPAP all night on two 12v coach batteries with no problem. I do not use humidifier when in RV. Knowing you brand and model of CPAP, plus your pressure number will help with a full answer.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
Dakota98
I have been using a CPAP for close to 20-years.
Do either or both of you use a humifier ?
How old are the CPAP's
Your answers will help with suggestions, I could offer.
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
time2roll
Couple options. Need to run CPAP can be done with 12v power direct in many cases. You need to check with your CPAP manufacturer if the proper adapter is available. Then you just need to get 12v power to where it is needed.
Or you can install a small sine wave inverter and plug into the closest 120v outlet.
Either way I recommend 2 to 4 batteries to keep the power on without worry.
Your RV dealer should be able to help you get this done if you are not mechanically inclined. Please post what the estimate says they are going to do so you know you are getting what you need. Not more, not less.
I am not fond of generators but another option is to run a Honda 2000 all night.
Here is some reading for being off-grid:
The 12 Volt Side of Life
romore
Unless you have a generator, you will need an inverter to run off the house batteries. They are not expensive, a modified sine model will do just fine, but you will need to find a convenient 12VDC source to plug into. Both machines will run off one unit, they don't draw much power. I wired one in when I had the nose in our fiver apart to fix some rot, we are no longer dependent on shore power for my wife's CPAP. Talk to your dealer about the best way to do this.
TucsonJim
My brother-in-law camps with us from time to time. We just fire up the Honda 3000 generator, put it on eco-mode and let it run all night. No problems.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
John_S_
We use a couple CPAPs and the batteries will last all night in the Foretravel but in the born free they will not so I just turn on the generator when we go to bed and not worry about it any longer.
John
2015 Born Free Royal Splendor on a Ford 550
2018 Rubicon
Boo Boo a Mi Kie
42' 36' & 34 Foretravels sold
2007 Born free 24 sold
2001 Wrangler sold
2012 Jeep Grand Cherokee Overland sold
Susie Dolly, Lolly &Doodle (CKC) now in our hearts and thoughts
donn0128
Probably not. Depending on the CPAP you have and whether you use the heater or not it could drain a single battery in a few hours of use. With two machines you would need multiple batteries, and a good inverter. There are battery powered machines that could work for you.
