I want to be sure the power tongue jack I’m having installed is adequate. The hitch weight is 525#. The jack is the “Husky 3000”.. Is that the only 2 weights to consider?
That will work just fine...remember, you don't have to lift the rear wheels of your truck completely off the ground...just take the tension off the spring bars.
