Which Hitch
Cathybil
I have a 2014 Silverado 1500. I just bought a TT. Passport 23RB. dry weight;4730, tongue wt; 525. Length 26’.
I was sold an Equalizer E4. Friends strongly recommend Reese Dual Cam.
I’m a new RV’er and have some physical problems.
Here’s my question;
1) which would have the best combo of “ease of use” and WD/Sway control?
2) I’m confused about the E4. Does it actually have a “cam” as well.
Thanks
12 REPLIES 12
Need-A-Vacation
As mentioned, both are great hitch systems!
Probably one area the Reese has a slight advantage over the Equal-I-Zer is the adjustment of the head. It allows a little more fine tuning when trying to adjust for proper weight transfer. Maybe nit picking a little though.
Bubba J- '13 Chevy Silverado 2500HD LT CCSB 4x4 6.0
'16 Jay Flight 32 BHDS ELITE 32 BHDS Mods Reese DC HP
WDH Set Up. How a WDH Works. CAT Scale How To.
Ron3rd
Here’s my question;
Thanks
Both are good hitches and both work on different principles. I've got The Equlizer 4pt setup and it works great. It does not use a cam light the Reese. Both have built in sway control and both have a big following.
Equilizer Hitch
Honda EU2000
Cathybil
Thanks Everyone !
3oaks
APT wrote:
The Equal-izer 4-pt is a good WDH with integrated sway control. The owners satisfaction rate seems to be about the same as the Reese dual cam system, both quite high. I would not change one for the other.
The EQ like most WDHs can be failry easy to hook up using the following procedure:
Lower tongue onto ball just enough to latch
Latch tongue on ball
Raise tongue/lower jack
Install WD bars
Lower tongue/raise jack
That procedure is greatly assisted with an electric tongue jack.
X2
And I will add, Any bolts associated with the Equal-i-zer hitch do not work loose when properly torqued to the manufacturers specifications.
I have been happy with my Equal-i-zer hitch going on 9 years. I have had not any experience with a Reese Dual Cam, but I hear owners are well satisfied with them too.
"Why do people want to complicate things? You have a fine hitch for your application use it! The cheapest hitch on the market is perfectly safe and more than adequate, unless you like spending money needlessly you are good!"
Obviously spoken by someone who has never experienced a serious trailer sway event- as I have with a cheap hitch. All hitches are not "adequate", and saying they are is extremely bad advice.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
rbtglove
Have used both but like the equilizer better much easier to set up and does the job just fine for your TT size.
Bob/Beavercreek OH
2011 Silverado 1500 LTZ/Trail Lite 8230
jmtandem
After towing with the Equalizer I definately would get the Reese Dual Cam. To answer your question the Equalizer does not have a cam, and any sway feature against sway also works against return from sway. The hitch has too many little parts, too many bolts that loosen and need to be retightend after each trip, and the spring bars are more bars and less spring. Dealers throw in the Equalizer hitch to make a sale.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
Sandia_Man
Either hitch would work fine for the towing combination you have. If you still want to get the dual cam hitch then go for it, but I doubt you will see much improvement over the equalizer hitch you already have. Your truck and TT are a good match and any decent WD/SC hitch will provide a comfortable towing experience. Enjoy your new Passport!!!
APT
Install WD bars
2017 Subaru Outback 3.6R
MarkTwain
I have had no experience with the Equalizer hitch. I tried a couple of other brands until I found the Reese Dual Cam hitch. I used the Reese for 15 years and had great experiences, easy to hook up and use. The greatest feature for me was the control and stability when traveling down the road. Passing big 18 wheelers comming at you was no longer a white knuckle hang on to the steering wheel experience.
The Reese Dual Cam really proved its control and stability when a car had a blow out when he was passing the trailer and his car rammed right into my rear wheels on my truck. My trailer travel from the right hand land clear over to the outer edge of the left hand lane. The trailer made a big S shaped turn but then came right back into the right lane with no damage. I just keep my hands firm on the steering wheel and allowed the Reese Dual Cam to straighten the trailer and truck up. I pulled over and stopped. The only damage was my rear fender and running board. A CHP happened to be traveling behind and saw the whole incident. :):) No damage to the trailer or the hitch and was able to continue on in to Ariz. The Dual Reese Cam provided me almost the same degree of stability features as my new 5th wheel Reese hitch and 5th. wheel. Made a believer out of me:)
pitch
Why do people want to complicate things? You have a fine hitch for your application use it! The cheapest hitch on the market is perfectly safe and more than adequate,unless you like spending money needlessly you are good!
Grandpere
I am not familiar with Equal-I-Zer's new nomenclature, but I can tell you from personal experience that you have the best hitch on the market. I have used them for the better part of 40 years pulling TTs and would not consider purchasing anything else. We decided to go with a MH this time just to try something different. If we ever go back to a TT we will get an Equal-I-Zer hitch for it.
Berniece & Russell Johnson
Lil'Bit, a Netherland Dwarf Rabbit
1987 Southwind
1995 Ford F150 Supercab
Life in the fast lane? No thanks, we will stop and smell the flowers at every opportuity
