โJun-21-2015 06:53 AM
โJun-23-2015 06:04 AM
redhooker wrote:
Edited:C Class 2s are as stated above-typed without reading and thinking-
I do compliance for a medical facility, and here are the rules for class 3s
Prescription must me either written or sent electronically through an e-scribe service. No call-ins or faxes. So yes, your Dr CAN e-scribe class 3s or higher.
No more than 6 months of all classes of pain meds without referral to pain management.
Many class 3 alternatives exist for those with class 2 Rxs, so if traveling try to switch to something else when on the road
WHY IS YOUR DR GIVING YOU A HARD TIME?
Because it's difficult to prescribe. We must report all scheduled RXs and coordinate with other prescribers to try to ensure no abuse is happening. Not only that but the DEA can and does from time to time come in and try to determine if the Dr's prescribing habits are within normal treatment protocols. In other words writing you pain meds is ironically now a PAIN so you will experience a lot of reluctance from most providers. I understand why the rules came about but unfortunately this sledgehammer approach makes legitimate patients suffer without needed medications. When I came up through school pain was considered a "fifth" vital sign and was taken seriously. Now many physicians could care less and just want to avoid the hassle.
โJun-22-2015 06:34 PM
โJun-22-2015 05:04 PM
โJun-22-2015 02:35 PM
โJun-22-2015 07:48 AM
โJun-22-2015 06:33 AM
Water-Bug wrote:
The end effect is that MOST pharmacies don't bother to fill the prescription until they have the hard copy. That way, Class 2 meds are all in one location until they have a valid hard copy prescription.
EDIT FAXING the prescription only has the effect of the pharmacy assuring that the have the med in stock. They still NEED the hard copy.
โJun-22-2015 06:25 AM
โJun-22-2015 06:11 AM
4X4Dodger wrote:
I am confused. Any doctor I know of will fax a prescription to any pharmacy in the country. Just tell your doctors office that you will be traveling and that you will need them to do this. Then call your doctor with the name and fax number of the pharmacy and...it's done..Am I missing something?
PART 1306 โ PRESCRIPTIONS(bold emphasis added)
CONTROLLED SUBSTANCES LISTED IN SCHEDULE II
ยง1306.11 Requirement of prescription.
(a) A pharmacist may dispense directly a controlled substance listed in Schedule II that is a prescription drug as determined under section 503 of the Federal Food, Drug, and Cosmetic Act (21 U.S.C. 353(b)) only pursuant to a written prescription signed by the practitioner, except as provided in paragraph (d) of this section. A paper prescription for a Schedule II controlled substance may be transmitted by the practitioner or the practitioner's agent to a pharmacy via facsimile equipment, provided that the original manually signed prescription is presented to the pharmacist for review prior to the actual dispensing of the controlled substance, except as noted in paragraph (e), (f), or (g) of this section. The original prescription shall be maintained in accordance with ยง1304.04(h) of this chapter.
โJun-22-2015 06:03 AM
โJun-22-2015 05:31 AM
โJun-22-2015 05:28 AM
โJun-22-2015 03:39 AM
โJun-22-2015 02:41 AM
Water-Bug wrote:
Doctors in Florida are really on edge over the issue. Internist won't even write a prescription for a class 2 drug. They refer you to a pain clinic/specialist. The specialist writes a prescription for one month at a time and do random blood and urine tests to assure that you are the person taking the drug and that you aren't self medication with street drugs. I'm sure that it is a CYA issue.
โJun-21-2015 11:08 PM
