โMay-13-2017 08:05 AM
โMay-15-2017 11:11 AM
B.O. Plenty wrote:
Why not just hook the hose for the grill to one tank and the trailer to the other with the changeover valve turned to the the tank the trailer is hooked up to. Keep it simple.
B.O.
โMay-15-2017 10:23 AM
โMay-14-2017 04:21 PM
โMay-14-2017 07:01 AM
mobeewan wrote:hybridmom wrote:bob213 wrote:
Between the tank and the regulator. Then you have full pressure to your outside appliance which probably has it's own regulator.
This is basically what my tanks look like. I don't think the brass 3 port piece will fit between the tank and regulator. Is there a different one, maybe with a short hose?
***Link Removed*** or ***Link Removed*** the Pol end will screw into the cylinder vale end (left hand threaded) and your acme nut will connect to the other end.
โMay-14-2017 06:32 AM
โMay-13-2017 07:12 PM
โMay-13-2017 11:33 AM
โMay-13-2017 10:23 AM
โMay-13-2017 10:22 AM
โMay-13-2017 09:59 AM
โMay-13-2017 09:14 AM
downtheroad wrote:
This>>>>>***Link Removed***
โMay-13-2017 08:22 AM
