โMay-12-2022 08:32 AM
โMay-17-2022 08:37 AM
โMay-17-2022 04:31 AM
Brownleaf wrote:
Grit dog, my biggest problem is with my computer, as I will type out a paragraph and the unit will delete everything I just wrote or write back over what I am writing.
โMay-16-2022 10:54 AM
โMay-15-2022 07:39 PM
Brownleaf wrote:
Grit dog, gennset was removed but drive could have caused it. So even if it is opening on its own, you are saying the leak detector going off is a down system issue. The tank is basically empty right now. If there is a tiny amount in it would it be unsafe to try a stove top burner? And in fact should I open it up to see if that leak detector comes back on? Doug
โMay-15-2022 06:43 PM
โMay-15-2022 06:17 PM
Brownleaf wrote:
Grit dog, my biggest problem is with my computer, as I will type out a paragraph and the unit will delete everything I just wrote or write back over what I am writing. I live alone and know little about computers. I say all to explain why I am not more verbose about issues. I may have bigger issues with my lp system. I am still checking to see if the valve closure was an error or it takes weeks to slowly open on its own. my 04,24 ft winnie stays in my driveway and I like to drive it once a week. I am doing various proejects such as recaulking and now rust removal from undercarriage. Doug
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โข <\br >Toys:
โMay-15-2022 06:11 PM
โMay-15-2022 04:55 PM
โMay-15-2022 10:51 AM
โMay-13-2022 04:47 PM
โMay-13-2022 04:37 PM
steveh27 wrote:Matt_Colie wrote:
I had to replace mine and the part was about 80$us and shop didn't change me any labor, but I would not count on that.
Matt
Matt, Where did you have that done? We are close & I may need it.
โMay-13-2022 03:42 PM
โMay-13-2022 11:40 AM
Brownleaf wrote:
On my motorhome ( perm. tank), I discoveed that my shut off valve opens back up partially after having been closed earlier. Is this an easy - simple relacement? Expensive? Doug
โMay-13-2022 03:14 AM
Matt
