bskomp wrote:
With all that being said I have a ? that I just can't' get a straight answer on. Answer on Will my a/c unit make a outlet drop below 20% voltage reading?
The reason you can not get A straight answer is that there is not one, there are many, depending on where you are parked and assorted other things.
I will explain...
In a modern park with COPPER lines and relative new hardware, on a site next to the power transformer, with cords and plugs on your RV in good condition.. NO, it won't.
But 30 amp cords and adapters do not remain in "Good condition" long, the plugs get.. Well, kind of nasty less you polish them (I do) often.. And if you have to use and extension cord.. Well that adds to the voltage drop.. IF the parks' outlet is a bit,,er,, nasty that adds to the voltage drop, so does an older breaker box with poor connections, an older breaker and one biggy ALUMINUM wires that were buried back around the time Hitler ran Germany... (Or for that matter even much later).
And the farther from the distribution box.. the greater the drop.
IF there is more than one site on your power chain, Then the drop increases even more as others "log in".
So you see, there no single answer..
how to monitor: I see many folks have recommended a meter Campign world sells for around 20 bucks.. I have one, works well, I use it to monitor the "AUX" circuit here.
Also I have a Kill-a-watt, it is on the primary circuit (Motor home has multiple 120 volt systems depending on site Im parked on).
