Rubber roof welding?
ScottG
This looks like a nice, neat way of sealing around stuff on the roof. Has anybody ever done this or have it on their roofs?
Scott
14 REPLIES 14
All_I_could_aff
If I was somewhere 110 degrees, the last thing on my mind would be my camper roof. I sweat like a pig at anything over 80
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollinโ€™ on 33โ€™s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
ItsyRV
Hot welding does create a material to material interconnect similar to melting ice to ice. It's probably the strongest of all material to material connections. When applied properly by an experienced trained technician, it should outlast any tape or adhesive bond. But, hot welding is limited in where it can be used and does not eliminate the use of lap sealant or tape on an RV roof.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
Cummins12V98
For a RV stick with self leveling Dicor and Eternabond.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
gbopp
I would probably take the 'belt and suspenders' approach and use Eternabond/Dicor on the welded seams. ๐Ÿ™‚
KM_Rolling
Looks nice, not sure it is any better than eternabond. Certainly more work, and the possibility of a mistake exists with this that does not with the eternabond.
Kevin & Mary
2018 Ford F150 3.5 EB HDPP 8' Bed - For Sale
2020 Ford F350 6.7 PSD 4X4 DRW CC LB
2019 Coachmen 271BL Toy Hauler
travelnutz
Smart people always avoid like the plague being in anyplace anytime where the outside temperature is 110 degrees F and the top of your RV is at 150 degrees F or even at 20 degrees lower. Problem solved as usual by the smart people!
A superb CC LB 4X4, GM HD Diesel, airbags, Rancho's, lots more
Lance Legend TC 11' 4", loaded including 3400 PP generator and my deluxe 2' X 7' rear porch
29 ft Carriage Carri-lite 5'er - a specially built gem
A like new '07 Sunline Solaris 26' TT
TurnThePage
I would assume, just like any weld, that it is now one piece. If something did fail, I wouldn't be surprised to see it be a section next to a weld.
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
DutchmenSport
What happens to the "weld" if you find yourself in the South West or the Bad Lands or somewhere like that, the sun is beating down at it's strongest, the outside temperature is 110 degrees and the top of the camper is 150? Will it curl up?
Bumpyroad
I would certainly trust/prefer welded material than stick on scotch tape type.
bumpy
MFL
Nomad II
Nomad II
That looks to be a pretty slick seal! I would have to wonder what may happen, with that heat weld method in the hands of the inexperienced? Yes, me, now having burned holes in my roof. ๐Ÿ™‚
Jerry
I also like the idea, but not sure how/if it would be done at home? Unless you are able to purchase that what looks to be specialty heat gun and nozzle.
Eternabond basically does the same thing with a-lot less labor..
Pretty cool product though ! !
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
TurnThePage
I like it!
2015 Ram 1500
enblethen
My daughter up in Lake Stevens has it on her mobile home. This is common installation for PVC roofing on commercial buildings.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Campfire_Time
That looks interesting but slow. Applying Eternabond isn't as much work as this appears to be.
Chuck D.
โ€œAdventure is just bad planning.โ€ - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
