RV tech. help on what sealant to use?
NanciL
I am going to be cutting a hole and installing a new cable entry port on the side of my brand new travel trailer.
What do the factories use for a sealant when they install them ?
Jack L
Jack & Nanci
25 REPLIES 25
ScottG
Dave H M wrote:
I do not hesitate to use quality silicone.
It will probably be there when some anthropologist digs it up. :W
Don't they even use that stuff to put aquariums together?
oops I forgot to mention that I am not an RV tech, just an old retired pfazrt. :W
I agree, I've never found anything that seals and holds better than 100%e clear silicone. But it has to be used correctly.
Make sure the area is cleaned with a solvent and put the silicone between the two surfaces. Then remove any silicone you can still see. (the worst enemy to silicone is sun light, which turns it yellow and will eventually break it down.)
I've siliconed doors and all kinds of things on the outside of my TT and it's still water tight after 12 years.
Cummins12V98
If someone did that quality of a caulking job on one of my jobs I would have beaten him to near death with the caulking gun, THEN fired him.
Unreal someone would actually publish this.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Dave_H_M
my, that video is something one has got to see.
yes i did enjoy it. nuf said. :B
myredracer
How to caulk RV exterior with silicone. Enjoy!
There are caulking products made specifically for RV exterior use. Why would anyone not use the correct product for the application? There are some alternatives to RV exterior caulk (like Geocel) if you do your research.
Cummins12V98
Basic silicone should be avoided! Pic from DRV's stock.
SH
I agree with the "no silicone" contingent. There are many good sealants available. Use a good poly urethane, tri-polymer or even a polyether or silane terminated polymer.
My current favorite is Bostik 1100FS followed by Sika 505UV and Chemlinks M1. Tremco has some good ones as well but are difficult to locate.
2001 Alpenlite 35RK
2007.5 Chev LMM Duramax/Allison
BD Variable Vane Turbo Brake
TST 507
2010 FLHTC Electra Glide Classic Red Hot Sunglo ๐Ÿ™‚
pianotuna
Nomad III
Nomad III
Don't use silicone.
The makers use something called "monkey tape". There are better products such as Pro Flex.
Regards, Don
STBRetired
I'm with SoundGuy. Geocel Pro Flex.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
Dave_H_M
SoundGuy
Geocel Pro flex RV Flexible Sealant, available in clear, white, black ... never use silicone on the exterior of the trailer, you'll never get anything to stick to it, including more silicone. ๐Ÿ˜ž
2012 Silverado 1500 Crew Cab
jplante4
On side walls, I've had good luck with clear silicon.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
