โAug-26-2020 11:15 AM
โAug-27-2020 06:27 AM
bgum wrote:
Yes it is OK. No advantage if you have 30 amps available.
โAug-26-2020 05:53 PM
cavie wrote:jdc1 wrote:Cummins12V98 wrote:
You may have less voltage drop on the 50 vs the 30A.
Or you could have more.
There will be no up or down in voltage. Voltage drop has to do with amp draw and wire size and distance, it does not accrue at the plug.What you will have is a better tighter connection with the 50 because of less use. Always plug your 30 into a 50 if available.
โAug-26-2020 05:04 PM
โAug-26-2020 03:53 PM
Charley67 wrote:
Thanks for the responses. My camper is 30 amp, and I can trip that outside breaker pretty easily.
โAug-26-2020 03:43 PM
โAug-26-2020 03:20 PM
โAug-26-2020 02:13 PM
โAug-26-2020 01:33 PM
โAug-26-2020 01:26 PM
โAug-26-2020 12:42 PM
โAug-26-2020 12:41 PM
โAug-26-2020 11:46 AM
โAug-26-2020 11:39 AM
โAug-26-2020 11:22 AM
