โJun-24-2018 04:45 PM
โJun-26-2018 08:16 PM
Old-Biscuit wrote:
Unless fridge is 'sideways' as in my 5vr.
Set cockeyed ----not side to side or front to back
I have two levels mounted on 5vr
One on pin box that I can see and use for side to side when parking 5vr on site
Then another one for front to back next to front landing gear controls
Set both for level and done
Fridge is turned OFF anytime we are stationary and NOT level.
โJun-26-2018 01:05 PM
โJun-26-2018 11:31 AM
Bobbo wrote:wa8yxm wrote:
How unlevel is 3 degrees?
Trailer wheel base 8'
Rise of 5" on one side (5 Inches off level)
2.98 Degrees per an online calculator
That is VERY off level. I like to keep the difference to 1.5 or less.
For SHORT periods. (IE: stopped for lunch) even greater angles won't matter.
But as you dricwe look for a 5% grade (you can find em in the nountrains
3 Degrees is 5.24 percent
You are correct. Except. The 3 degrees off level is the refrigerator's left to right. Since the refrigerator is sitting with the door facing side to side in the RV, the refrigerator's left to right corresponds to the RV's front to back. Do your calculations again using the RV's length instead of its width. For your calculations, the amount of off level that Dometic quoted is 6 degrees.
โJun-26-2018 10:01 AM
โJun-26-2018 05:50 AM
โJun-25-2018 07:41 PM
โJun-25-2018 07:10 PM
delwhjr wrote:
The refrigerator should not be more than 3 degrees unlevel left to right, or 6 degrees unlevel front to back.
โJun-25-2018 06:53 PM
โJun-25-2018 05:19 PM
mosseater wrote:
I turn ours off is it's too unlevel. Cheap insurance.
โJun-25-2018 04:56 PM
โJun-25-2018 04:15 PM
delwhjr wrote:
Direct quote from Dometic about being level:
"Thank you for contacting Dometic. The refrigerator should not be more than 3 degrees unlevel left to right, or 6 degrees unlevel front to back. We do not recommend having the unit unlevel for more than 1-2 hours as this can increase the chances of a blockage. However, we do recommend if you can, have the unit level at all times."
โJun-25-2018 04:08 PM
โJun-25-2018 03:51 PM
โJun-25-2018 08:55 AM
