Silverado 1500 Towing
genekiwi
Anyone know the towing capacity for a 2013 Silverado 1500 Crew Cab 5.3 engine with 3.42 rear end with trailer package?
Can't find anything on line. Dealer says 9600 pounds but not sure about that.
Considering buying one to tow about a 7500 pound trailer.
I know it will not be the fastest but that is okay.
Thanks
GeneKiwi
2013 Heartland Caliber 26RLSS (Dislike the quality)
2013 Chevy Silverado 1500 (Love the truck)
78 REPLIES 78
mkirsch
Nomad II
Nomad II
Bob Landry wrote:
I can't think of anything about that engine rear end combination that you are going to like towing that size trailer. That truck is a grocery getter.
The 6-speed transmission in the middle makes it tow more like a 4.10 rear end than a 3.42.
7500lbs is, IMHO, the *practical* maximum for the Chevy 1500 platform, even with the juiced-up 5.3L and 6-speed transmission.
ependydad
Can you ask the dealer for the stickers from the doorjamb? One will show the GVWR and the other will show the maximum cargo capacity.
From those numbers, you can start to get a feel for what you can actually carry:
What Can I Tow?
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
The_Texan
Why not post a chart for the GM 1500 with the 6.2 and a 3.73 instead of the Ford. Both have similar torque and identical gears.....It is definitely better than the 5.3 with 3.42
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
2005 HR Endeavor 40PRQ, '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2017 Rzr 4-900 riding in 16+' enclosed trailer in back.
Where the wheels are stopped today
APT
BenK wrote:
A 3.42 diff is not a good choice for towing heavy (for the vehicle
class and you have gone down to the lowest class full sized pickup)
Worse if you put on over sized tires. The ratio from the OEM tire
dia to whatever you end up with will the the same ratio applied to
the diff ratio (reduction in towing capacity)
With the 5.3L and the 3.42, definitely going to be slow on the flats
and even slower on inclines and altitude.
That is simply not true with the 6-spd trans. The 5.3L/6-spd/3.42 will allow for 4 or 5 usable towing gears. First gear is like the old 4-spds with 4.56 axle, shorter gear spacing.
Are there better ones now? Sure. Compare to the F-150 Ecoboost 3.73:
2017 Subaru Outback 3.6R
goducks10
genekiwi wrote:
Okay, I get the point. More power more towing. AND I want to say thanks for ALL of the input.
Numbers I got:
Trailer towing weight: 9600
trailer dry weight 5695, max weight 8600 I took 7000 as a mid range weight.
I think the combined max weight is 15000.
Hitch weight is 572
Payload weight is about 1700
I don't have the truck to get definite numbers off of.
I liked the truck because it has a built in sway control and engine braking downhill. Better gas mileage is also a plus over the 2500 since not all of my driving is done towing.
I have owned the 2500HD for 6 years and time to retire it.
Besides, at my stage of maturity, this may well be my last truck that I will buy. ๐Ÿ˜‰
Seriously, I know what you are talking about. I had an 02 1500 with the 4.8 and 4 speed. I towed a Jayco Kiwi 23B and yes, it was slow on the hills and I hit 35 mph at the top of one pass.
The Heartland I own is not quite 11 feet and has the rounded or slopped front which I hope will help. The Jayco I had was 11 plus and a flat front.
Neither the dw or I tow faster than 65 and usually in the 60 range.
Besides, I am retired and not in any hurry.
Again, your comments were and are appreciated.
Let me guess you have a NT 26LRSS? Those are the same numbers I have.
Ours came in at 6189lbs shipping. Weighs 72-7300lbs loaded. TW 900+/-,
We towed it with an F150 5.4 (sim to 5.3) but had 3.73 and the 6sp. It did fine on the flats an okay in the mtns. Never really had all that much trouble climbing passes. On the Ford, the culprut was the non seletable 6sp tranny. Went in whatever gear it wanted when it wanted. I'm pretty sure your Chevy has the select mode. Handlings was fine in the mtns/hills as the truck was not trying to keep the TT straight with all the cornering. Out in the wide open flat freeways is when things weren't as solid. I used a 1200lb Equal I zer hitch. I now have a 2500 and it's a lot nicer to tow. Any TT movement was felt in the F150, hardley at all in the 2500. 7-7500lbs is borderline for most F150's IMO, sure the tow ratings are there but it's still a 1/2 ton and more susceptible to trailer imput. FWIW 8.5 mpg.
The_Texan
IF you can find one, and they are hard to find as most dealers won't stock one, the 1500 with the 6.2L 3.73 max tow package is an awesome towing machine for the weight you are talking. We routinely tow 10K with ours here in the mountainous west and have NO problems. The difference between our old 5.3L 3.42 towing package and the new one is night and day. You do not need a ยพt truck, if you have a properly equipped 1500.
BenK
First, suggest you read page 346 of the manual Ron posted (GREAT that
you can find this stuff).
Here it is:
Take note of the upper right paragraph and it means that they used
the base model, curb model, which is the stripper model with NOTHING
other than the towing option, a 150lb driver, fluids (depends too
as some only use half a tank, etc) and the hitch.
NOTHING
else and as it says, every thing else loaded
onto/into the TV will subtract, pound for pound, from the MTWR (they
call it TWR, which is more correct).
Numbers I got:
So, unless you have that 'curb' (aka stripper) model, this does NOT
apply to your TV. It will be less by the stuff loaded into/onto the TV
That 'dry' is the curb or stripper model. It will weigh more after
the propane (some times even the empty bottles are not included), etc
are added
Assume that 8.6K is the trailer GVWR
Hitch weight is 572
Again, this is based on the curb vehicle. Some OEMs are getting better
and have that yellow label, which uses the shipping weight vs GVWR
Hope you understand that you are going from a +9K GVWR down to a +7K GVWR
truck. Huge difference.
Don't know what trailer other than your 8.6K GVWR. Most will weigh
much more than their listed 'dry' weight and depending on how you
load, many find that they end up very close to their trailer GVWR
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
APT
Sounds like a good combo. I still recommend the 6.2L. ๐Ÿ™‚ Or, if you only use the truck for towing, keep your old 2500 and get a new daily driver that is more comfortable and gets better fuel economy.
The built in sway control and engine grade braking are not very important for RVing IMHO. The sway control hopefully never be activated as that would be a pucker moment.
genekiwi
Numbers I got:
Hitch weight is 572
GeneKiwi
gcloss
Lesson # 1
Don't listen to a car salesman. His only interest is selling you a vehicle to earn his commission.
Lesson # 2
Do you homework via the internet. There is plenty of information available to help you make a decision on the right tow vehicle.
2012 Ram 2500 Big Horn Crew Cab 8' box
5.7 Hemi, 4x4, 4.10
2015 Jayco Eagle 284BHBE
mooky_stinks
According to my 2012 owners manual a 1500 2wd Crew Cab 5.3 3.42 can tow 9600lbs.
A 1500 4wd Crew Cab 5.3 3.42 can tow 9500lbs. This is out of secton 9 Driving and Towing of my 2012 owners manual. I quoted both the 4wd 2wd since it wasn't specified which one you were interested in.
2020 F150 XL Screw 4x4 6.5โ€box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
Jayco-noslide
Pretty sure your owner's manual will tell you but you can also look it up through Trailer Life Mag as they put out a towing guide every year. It is tricky to make sure you find the right listing for your truck but it's there. My 2007 Chevy 4-w drive with 5.3 motor and 3.73 rearend is rated for about 7,700 I think and I comfortably tow a small 5th wheel with dry wt. of 5,300 lbs.
Jayco-noslide
Ron_Gratz
The answer to your question can be found in the online 2013 Silverado Owners Manual in the charts beginning on page 9-79 (347/542).
The value also depends on bed length and 2WD or 4WD.
Ron
APT
7500 pounds dry if too much for most half tons, that truck included. Add 1000-1500 pounds for the typical RVing family.
If the RV has a 7500 pounds GVWR, then it might be good. I recommend under 6000 pounds dry for the most capable half tons. Usually some other rating is exceeded if towing an RV at the tow rating. Receiver, payload, rear axle are likely to be exceeded for a 9500-ish pound RV. Most 9500 pound boats would be fine. ๐Ÿ™‚
3.42 axle is fine with the 6-spd trans. It provides better overall gearing than an old 4-spd with 4.56 gears. GM does not offer a 3.73 axle with the 5.3L. IF you really want a new GM half ton, I highly recommend the 6.2L/NHT package. A lot more power, a little more payload. Anything wrong with your current 3/4 ton?
Bob_Landry
There is nothing about the combination that is going to make for a happy towing experience. Payload capacity of the truck is also going to be an issue, but you seem to be sold on the truck.
2011 Keystone Outback 277RL
