Splendid 2100
DC_MC
Our splendide started making horrible rattling type sounds when it was trying to pump water out of the machine. Water did not pump out, I opened the cleanout on the front and drained it. A small green piece with 4 propellers on it fell out after I removed the cap. Is that piece supposed to be fastened to the shaft that you can see in there. Is this something that broke loose and that's why it's rattling and won't pump out?
2006 Mandalay 40E motorcoach
2017 Ram PU
2017 Harley Road King
Home base Yuma AZ
3 REPLIES 3
DC_MC
Called splendide, he said yo try JB weld first. Sometimes that works
2017 Ram PU
Home base Yuma AZ
jetcare
The green piece is indeed part of the pump. Time for a new pump. You need to change the pump from the back side of the machine.
2016 F-250 Crewcab 6.2L 4x4
2012 Palomino Sabre 32' Travel Trailer
donn0128
Call Westland Sales in Clackamas and ask them. It sounds like the water pump has failed.
