Storage and Slides
1L243
I leave the side in when I store may Toy Hauler. Would it be a good idea to back off the slide maybe a inch or so, so the slide gasket is not compressed for months at a time?
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
6 REPLIES 6
ScottG
I wouldn't. When a slide is slightly out there's often a small opening at the lower corners. Perfect for Mickey to get in.
MFL
Nomad II
Nomad II
Most seals, mine are D-bulb, are pretty resilient. I prefer to leave my slides all the way in. I have noticed after long term, they are a little flat, when first opening, but they quickly return to normal shape. My owners manual also says to store with slides in, for long term storage, which I'm sure means all the way in.
Jerry
rav
we always stored ours with the slides all the way in during the winter months and had no issues. the campers were stored outside. I would always treat them with a seal conditioner before storage. our MH was 9 years old and the original seals were still fine
1L243
I should had that my rig is stored out of the weather and no chance of water getting in...
rk911
we store our MH with the slides in. lessens the chance of accidental damage by those parked next to us among other reasons.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
fj12ryder
I don't see any need for it. We store ours for months at a time and the gaskets/seals are still fully functional. You may risk a water leak if the seals aren't working as they are designed.
Howard and Peggy
"Don't Panic"
