โDec-05-2016 06:38 AM
โDec-27-2016 05:09 PM
โDec-15-2016 06:45 AM
โDec-14-2016 07:48 PM
โDec-07-2016 04:28 PM
โDec-07-2016 09:27 AM
โDec-07-2016 07:44 AM
pyoung47 wrote:The weight distribution hitch can put back whatever weight was taken off the front by using a longer shank and take out whatever sag may have occurred. I can tell you from my own experience, putting a 2" longer shank on my F250 to clear the tongue jack wasn't even measurable at the scale.
I have a much longer hitch extension that came with a travel trailer that I had a few years ago. I never used it. I would think that the added length would add much more leverage to the both the vertical and horizontal. This would increase the sag of the truck and cause more instability in wind and when semis go past.
โDec-07-2016 06:56 AM
โDec-06-2016 05:25 AM
โDec-05-2016 08:09 PM
IBcarguy wrote:
I use an equalizer hitch, although I'm not so sure I really need it. This truck is pretty level even with out using the bars.
I like the idea of rotating the power jack 45 degrees, I'll try that before I do anything.
โDec-05-2016 04:37 PM
old guy wrote:
wow that jack E Up is some kind of device. only problem is you need a hand crank jack, it doesn't show using an electric jack.
โDec-05-2016 02:19 PM
โDec-05-2016 01:25 PM
โDec-05-2016 12:45 PM
โDec-05-2016 12:30 PM
