Tire Covers cont...
SH
I was reading the other thread about covers and was wondering if anyone has ever questioned covers causing tire damage. The photo below is a relatively new set of ADCO covers (two months or so) on a new set of Goodyear 614s. There is a noticeable brown stain where the tires contact the covers. Could the covers be drawing out any important chemicals/oils from the new tires?
2001 Alpenlite 35RK
2007.5 Chev LMM Duramax/Allison
BD Variable Vane Turbo Brake
TST 507
2010 FLHTC Electra Glide Classic Red Hot Sunglo ๐Ÿ™‚
13 REPLIES 13
NC_Hauler
larry barnhart wrote:
Black covers make heat. white is better. Do I have to tell you guys everything!!!!!!!!
chevman
Mine is parked in the shade Larry:B
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
larry_barnhart
messed up because of visiting here at home sorry
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
larry_barnhart
chevman
chevman
prodigy
scanguage II
TD-EOC
TST tire monitors
FMCA # F479110
SH
NC Hauler wrote:
AND.....if you use the BLACK COVERS instead of the white covers.....this wouldn't be a problem..........because you would have never seen it:B;)
Good Plan! :B
2001 Alpenlite 35RK
TST 507
NC_Hauler
B&W RVK3600 Hitch
C-Bears
You have to be careful of what tire covering material you utilize. A waterproof non-breathable material will trap moisture and cause damage to your tires.
Remember the only purpose of tire covers are to keep the sun from damaging your expensive tires while camped or stored.
2014 Montana 3725RL (Goodyear G614 Tires, Flow Thru TPMS)
SPENDING THE WINTERS AT OUR HOME IN SW FLORIDA. THE REST OF THE YEAR SEEING THE U.S. FROM OUR LIVING ROOM WINDOW!
westend
I guess it might be possible but both materials, the tires and the covers, are made from rather inert materials. With the tire you're looking at probably synthetic butyl rubber and coal black as the main ingredients and the cover would be some type of spun plastic, a long chain polymer like polyethylene or nylon. There is just not much chemical affinity between the two to have a chemical reaction. If anything, I would assume the coal oil in the tire could cause the cover to change.
The cover discoloration may be from the elongation or compression of the cover material, causing it to hold dust. Could also be a solution was applied at the tire dealer. I know most use a soap solution to mount tires. It may have tire dressing on it as well.
'03 F-250 4x4 CC
larry_barnhart
Tire dressing stains? Chevman
chevman
prodigy
scanguage II
TD-EOC
TST tire monitors
FMCA # F479110
SH
unclescratch wrote:
That brown color looks like dirt on the outside.
Nope...not dirt! A little dirt at the bottom since it just rained but the stain is on the inside as well!
2001 Alpenlite 35RK
TST 507
brirene
My covers, the same thing which have covered 2 new sets of tires, have never done that. I agree it's something that has been applied to the tires.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
unclescratch
I would remove the cover and see if the stain is on the inside of the cover. That brown color looks like dirt on the outside.
Community Alumni
Not applicable
I have only ever had that happen once on my tire covers. Our prior rv ( class A) the tire covers leached out some of a protectant that my rv dealer had treated the tires with.
There is really nothing to be concerned.
gbopp
Or are the covers reacting to chemicals in or on the tires?
Were the tires sprayed with anything?
I spray our tires with 303, if you rub the tire it will leave a stain on your clothing.
I don't know. It is an interesting question.
Hopefully another member has the answer.
