โNov-21-2016 04:39 PM
โNov-24-2016 09:14 AM
โNov-23-2016 04:00 PM
Turtle n Peeps wrote:
Ok, the first thing you have to answer is did the tire really blow? When tires "blow" it is LOUD because there is a lot of pressure and energy! Most of the time a tire loses pressure and then they get so hot the scissor off of the rim and then they come apart. This is why I've seen lots of trailers driving on a rim or driving on a flat tire.
How did you find out the tire went away? I've never had a "blown" tire in 35+ years of RVing. I've had many flat tires. Some I caught in time..............some I didn't.
Did you have a TPM on your tire that blew? What did the tire look like after you got your rig stopped? Was there anything left on the rim?
My point is, it won't matter what kind of tire you put on if you had a puncture and lost air pressure and the tire came apart.
โNov-23-2016 03:48 PM
coolbreeze01 wrote:
I had good luck with Maxxis but if buying today, I would probably go with the Carlisle HD load range E.
โNov-22-2016 08:57 AM
โNov-22-2016 06:09 AM
โNov-21-2016 09:23 PM
โNov-21-2016 07:05 PM
3oaks wrote:
I would go with Maxxis or Carlisle HD tires.
โNov-21-2016 06:34 PM
JIMNLIN wrote:
The Provider ST225/75-15 D at 2540 lbs capacity/65 psi. Four tires = 10160 lb capacity. You sure don't need a load E tire at 80 psi for that size trailer.
The Provider has a M speed rating (81mph) and has the nylon overlay that the newer gen ST tires come with. Higher speed rating is much to do with with standing heat issues/etc.
Also the Goodyear Wrangler HT in a LT215/75-15 D at 2180 lb capacity will give you 8740 lbs capacity .....well above your trailer axle/wheel load ratings.
These tire are good for 6-8 years and 35k-40k miles if you travel a lot. Their speed rating is whatever you want to travel at.....and available at any Goodyear store in the USA.
โNov-21-2016 05:34 PM
โNov-21-2016 05:28 PM
MFL wrote:
I agree with 3oaks, and will add another... Provider (see at E-trailer).
Jerry
โNov-21-2016 05:27 PM
โNov-21-2016 04:48 PM
โNov-21-2016 04:43 PM
