Tire pressure sensors
Bob_Vaughn
I have an add on tire pressure system on my rv. I recently got a new truck with built in tire pressure monitors so I took the 2 add ons from my old truck and put them on my spare tires on my rv. I tried to reprogram the monitor with the changed locations and also removed and checked the batteries. When I tried to reprogram the monitor I cannot get it to recognize 3 of the 6 sensors. They worked fine before I started. Now I do not know what to do. I am getting a headache from reading and re-reading the install instructions.....
6 REPLIES 6
loggenrock
Do you have them attached to the valve stems when they are near the monitor? Some systems turn the sending units off if there isn't any air pressure against them... ST
Two and a hound in a 2015 Coachmen Prism "B+"...pushed by '09 Suby Forester
First 50 done, working on the second pass! Nunavut - we'll see...!
2005-2015 Roadtrek 190P
1993-2005 Northstar Soft-Side TC
1989-1993 Backpacks & Tents!
1967-1977 Family TT's
Bob_Vaughn
I have replaced the batteries, I have the monitor right beside the camper, some read and some do not. They were fine last 3 months ago. My rv is indoors so they are not exposed to the elements. I have also removed and replaced them. Air escapes when I remove them so I know they are contacting the core. I wonder if there may be a way to clean them?
Duck
If your spare tire is tucked up under the rear of the trailer the signal from the tire is not getting to the receiver. On the other tire monitors that are giving you trouble try taking them off and re seat them again. I had one with a similar problem and that solved the problem.
Don
08-FORD F350 PSD
13 Bighorn 3055RL {For Sale}
loggenrock
Where are the spare tires located? Rear bumper? Possibly not a strong enough signal from the sensors to reach the location of the main monitor... Could just be weak batteries in the sensors - might be an easy fix. I know that TST makes a repeater for their units for very long rigs... ST
Bob_Vaughn
Tire Minder
Ron3rd
Bob, what brand is your rv's TPMS?
Equilizer Hitch
Honda EU2000
