Tongue weights
thehippie
My weight dist hitch is rated 1200 lbs tongue weight and the trailer I'm getting tomorrow is 1300 lb tongue weight. Will the difference of 100 lbs be abit ok ? I'm towing it with a 2015 ram Cummins longbed.
Weight of trailer is 7900 lbs and wdh is 12000 lb capacity.
I'll be ordering a bigger wdh soon
Thanks for any reply
7 REPLIES 7
thehippie
I think Iโ€™ll just get a 1,500 lb TW shank. And still use the same bars and head.
1L243
If your going by manufacturer specs on tongue weight you can't count on it being accurate. Usually the manufacturer seems to under rate the the TW. Maybe because they are not including propane bottles battery and a loaded trailer.
Your 12k hitch will be fine for getting your new trailer home. Once home you can do a little measuring. Without the trailer connected measure the distance from the top of your wheel wells front and rear to the ground (write it down) Now measure again with the trailer connected without the WDH (write it down) Now connect your WDH as you normally would and measure again (write it down) Now look at the numbers with the WDH. If your front was at 30" empty without the trailer 32" with the trailer but no WDH and now 30"to 31" with the WDH you are actually transferring some of that TW to the front of the truck. If you don't get any movement in that direction you either have to grab another link or go to a heavier WDH
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
jplante4
Moved from General RVing.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
souraider
I agree with others. Use what you have, and then if you are unhappy you can change out to a heavier spring bar...unless you are just looking for a reason to upgrade:)
'17 F350 STX 6.7
'15 Stealth WA2313
'20 Can Am Maverick Sport 1000R
dodge_guy
You want to have the hitch weight around 12% of the trailers loaded for travel weight. this means loading the trailer properly to arrive at the 12% hitch weight number. so your looking at around 9300lb loaded. that will be approx. 1250lbs. I would stick with your current hitch. to heavy of WD bars could cause issues.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
eHoefler
The rating for a WDH is for the bars, not the head. 1200 pound bars will transfer 1200 pounds to the steer and trailer axles. Most manufactures use the same head and change out the bars for the amount of weight needed to transfer.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
mosseater
I run about 1100-1200 lbs on a Reese Dual cam with 1200 lb bars and It seems to work fine. I can't believe being 100 lbs on the other side would be a problem for short term.
"It`s not important that you know all the answers, it`s only important to know where to get all the answers" Arone Kleamyck
"...An unarmed man can only flee from evil, and evil is not overcome by fleeing from it." Col. Jeff Cooper
Sunset Creek 298 BH
