โMay-04-2018 08:40 AM
โMay-05-2018 12:47 PM
โMay-05-2018 08:54 AM
BarneyS wrote:
The OP is talking about the bolt on the inside part of the snap-up bracket. It is a single bolt that contacts the A frame. I should be tightened only enough to keep the snap-up from moving around when there is no tension on it and it will also help keep the brackets from sliding forward or backward when the WD bars move during a turn.
โMay-05-2018 08:23 AM
โMay-04-2018 01:14 PM
โMay-04-2018 12:55 PM
thehippie wrote:downtheroad wrote:Reese
OK, let's start with the manufacturer or model of you hitch...Equal-i-zer, Reece, BlueOx, etc....then you will get more accurate information.
โMay-04-2018 11:18 AM
โMay-04-2018 10:50 AM
โMay-04-2018 10:38 AM
STBRetired wrote:no wrench just hand
Perhaps the mechanic meant use a wrench and you hand as opposer to an impact wrench.
โMay-04-2018 10:29 AM
โMay-04-2018 10:04 AM
โMay-04-2018 09:43 AM
โMay-04-2018 09:25 AM
โMay-04-2018 09:18 AM
โMay-04-2018 09:14 AM
