Tow bar braking
outboardfever
Does the Blue Ox Autostop tow bar elimanate the need for a braking device inside the towed car?
6 REPLIES 6
FIRE_UP
Well,
Yes & No. Yes, in the fact that you won't need any of those "Robots" that sit on the floor and you need to hook to the brake pedal every time you get ready to tow. No, in the fact that, that Blue Ox unit is identical to the NSA Ready Brake unit. It's an inertia operated mechanism that sits in between your tow bar and your coaches receiver.
Like the Ready Brake, it pulls on a cable that is attached to your brake pedal in the toad. It's a simple mechanism. We used the Ready Brake system for years. I recently changed over to the M&G system. Way cleaner and, it's not effected by the exhaust brake on the coach, like the Ready Brake was.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
EsoxLucius
kalynzoo wrote:
I just looked up Autostop and it appears that Blue Ox now has a system similar to NSA Ready Brake.
The Blue Ox Autostop has been around for at least ten years. That said, I found that it doesn't work well.
2013 LTV Unity MB Theater Seats
635 watts solar panels, 440 AH batteries, BlueSky Solar Boost 3024iL & IPN-Pro Remote, Magnum MS2000 & ME-RC50 remote
Koni Shocks F & R, Hellwig 7254, SumoSprings F & R
2012 Hyundai Accent SE, Blue Ox Aladdin/Patriot
avan
The answer to your question is "yes". (PS. Works well)
www.putt10.net
kalynzoo
I stand corrected. I just looked up Autostop and it appears that Blue Ox now has a system similar to NSA Ready Brake. Again, it will have to be drilled through the car firewall and attached to the brake peddle.
kalynzoo
I also think you are referring to the NSA Ready Brake. I have the adaptor which permits me to use the Ready Brake with any towbar, I have Demco. It inserts between the towbar and the motorhome, a surge mechanism then manually engages the toad brake by pulling a line drilled into the cab. I like the systems simplicity.
gbopp
I don't know anything about the Blue Ox but, it sounds a lot like the Ready Brake.
It pulls on a cable attached to the brake pedal. Nothing else is needed inside the toad.
