โJul-11-2016 11:56 AM
โJul-21-2016 08:29 PM
โJul-16-2016 09:30 AM
bayoubelle wrote:
One vehicle requires you to pull the DLIS fuse and another says to disconnect a battery cable. I am pretty sure this means the tail lights will no longer work. You can replace the fuse with a plug, fuse and switch as it is often difficult to replace the fuse.
The toad lights will get their power from the MH. You can install diodes, additional bulbs in the tail light area, magnetic lights etc.
Will they work once the vehicle is attached to the tow bar or do we need to add special tail lights?
Also, on a side note, will odometer register when we tow? Many do not register on the odometer.
โJul-16-2016 09:13 AM
Horizon170 wrote:Bumpyroad wrote:Horizon170 wrote:
Is the GVWR and GCWR set by the manufacturer? If so is that to make sure the Company is protected rather than what is actually safe.
My, new to me, Class "C" Is within 1000# of the vehicles GVWR So that means that I can't pull an added 2400 pound Fiat plus a tow dolly 600#. If the Mfg. says that I cant then it's BS IMO and perfectly safe with Tow Dolly brakes.
I'll bet that most RV's are well over the GVWR/GCWR and still are perfectly legal according to the States legal axle weights.
Marvin
but what if the lawyer for the person you hit with that "illegal" combination happens to read the data on the GVWR?
bumpy
That is what I'm worried about. I'll have to check with my Attorney on the legality of mfg's GCVW ratings. I wonder if anyone will post that they tow over the GCVW?
Marvin
โJul-16-2016 03:32 AM
Marvin
bumpy
Marvin
โJul-15-2016 04:39 PM
Marvin
bumpy
โJul-15-2016 04:01 AM
Marvin
โJul-14-2016 06:19 PM
โJul-12-2016 07:58 AM
bayoubelle wrote:
...We will be towing with a small Class C, we haven't even bought that yet, so we wanted to keep the weight down, since we are trying to keep the RV under 30"
โJul-12-2016 05:41 AM
โJul-11-2016 07:32 PM
โJul-11-2016 06:11 PM
Bumpyroad wrote:I saw that! They were on sale in the last sales flyer Harbor Freight sent in the mail.SoCalDesertRider wrote:you can get the magnetics for about $10 at HF on sale. I will not cut into any of my toads wiring for diodes, etc.
I have a set of magnetic towing lights that plug into the truck's trailer light wiring plug. The magnetic towing lights usually cost around $40 and are available at various auto parts and trailer supply shops, Harbor Freight, Tractor Supply, or from lots of online stores.
bumpy
โJul-11-2016 05:54 PM
rk911 wrote:obgraham wrote:I will not cut into any of my toads wiring for diodes, etc.I think likewise.
But the Honda CRV's were nifty in that there was an empty sector in the rear light assembly, so I had a separate tail/brake light placed here with its own wiring.
after a disasterous first-time towing experience with diodes I did the same with my Jeep Wrangler...separate tail light bulbs and a totally independent wiring harness for them used exclusively when towing.
โJul-11-2016 05:28 PM
โJul-11-2016 05:12 PM
