โMar-10-2014 07:18 PM
โMar-25-2014 01:01 PM
โMar-22-2014 06:37 PM
Uncutbulldog wrote:
So after all of the weight concerns and my weak Sunseeker engine, we bought a 2014 Ford Fiesta SE Hatchback. I weighed it today at 2520 lbs. I think this will be a more comfortable drive when pulling it with our MH.
With this light vehicle, can I get away with no breaking system?
2015 ForestRiver Sunseeker 3170ds:
Dry weight: 12,378
GCWR: 22,000 lbs
GVWR: 14,500 lbs
Engine: Ford 6.8L V10 E450
Hitch rating :7.5k/750
2014 Ford Fiesta SE Hatchback:
Weight: 2520 lbs
โMar-22-2014 06:08 PM
โMar-22-2014 06:02 PM
โMar-21-2014 11:10 PM
โMar-21-2014 09:05 PM
MikeRP wrote:
Hi,
I have the 3010ds which is the exact size as the 3170. Fully loaded I am 13500lb fully equipped for travel. I had my 2012 upgraded to the 7500 lb hitch this winter and it should tow the burb fine. I will be towing a jeep GC 4 down. You will be long so you'll want to take it easy till you get used to the burb. I used the Blackhawk 10000lb tow bar. I also have a 2500 burb I could tow, it weighs about 6300 lbs.
โMar-21-2014 07:12 PM
โMar-19-2014 07:39 AM
โMar-19-2014 07:32 AM
โMar-14-2014 05:21 AM
Uncutbulldog wrote:
Thanks guys. I truly value all of your expertise. I do plan on having the Sunseeker for a while. So I am starting to think I will not tow at all. Unless I get small vehicle just for towing.
My last concern in the CCC. The 2015 Sunseeker I ordered has every option (satellite, auto levelers, etc). Has anyone on here ordered a fully loaded Sunseeker recently?
What was your CCC? estimates?
I may have screwed myself by doing that (10% down/ordered already). I will have to wait and see until I go and pick it up. I heard they weight each RV and put a little sticker on the door. I will also be weighing it myself.
Thanks,
Jeff
โMar-14-2014 05:01 AM
โMar-13-2014 05:25 AM
Uncutbulldog wrote:
Earnest,
Thank you for your reply. I want my family to be safe. I checked with forest river and my hitch is indeed going to be 7500/750. I will have a braking system in the suburban as well.
Do you still have the same concerns?
Thanks again for your input.
Jeff
โMar-12-2014 08:16 PM
โMar-12-2014 04:23 PM
Uncutbulldog wrote:
Hello All,
First post of many I hope. My wife and I are buying our first RV soon.
My wife and I are thinking about buying a 2014 Forest River 3170ds. My question is will I be able to dinghy pull my 2003 Suburban 1500 4X4 (safely).
We have a family of seven so we want to be able to sleep 8 and tow our suburban anywhere we go.
We love the 3170ds but I want to make sure I can pull my suburban with it. If not, any suggestions one what motorhome to buy that will sleep 7 and pull our suburban?
2014 ForestRiver Sunseeker 3170ds:
Dry weight: 12,378
GCWR: 22,000 lbs
GVWR: 14,500 lbs
Hitch rating: 5K/500Hitch rating :5k/500
2003 Suburban:
Curb Weight 5219Curb Weight 5219 lbs
