Towing a Ford Escape Hybrid Auto-Trans, 2WD
Campnfuls
After many years of traveling with my travel trailer in tow, I finally switched to RVing in a Class A MH. I am looking to purchase a 2008 Ford Escape Hybrid to serve as my dingy. For those who tow a Ford Escape Hybrid using a tow dolly: Other than putting the transmission in neutral, securing the steering wheel, and releasing the parking brake is there any other precaution I need to consider or required step I need to make before towing with the rear 2 wheels down?
I want to leave this earth quietly in my sleep like my grandfather and not like the hysterical, screaming passengers riding in granddad's RV just before the big crash.:E
11 REPLIES 11
mowermech
I tow my Jeep with a $145 fixed arm adjustable width A-frame towbar. It works.
I tow the PT Cruiser on a Demco Kar Kaddy dolly. I use the dolly because it was inexpensive ($700, used), I have read enough horror stories about lube pumps that I don't trust them (the car has one in it, I should take it out and sell it. IF it works), and I didn't want to spend the money on towing brackets for the '06 PT.
Also, I find that the horror stories promulgated by the dolly doomsayers and naysayers are purely personal opinions that have absolutely no direct relationship to MY likes and dislikes. I don't find using the dolly at all difficult!
CM1, USN (RET)
2017 Jayco TT
DouglasC
Thanks to "Willald" for clarifying the situation. As noted above, I have been towing vehicles 4 wheels down for 21 years. During that time I have had only 2 different tow bars but 7 different base plates.
I have used Roadmaster tow bars and base plates and they are great about refurbishing older tow bars when possible at minimal cost. In my case, by the time I was ready to have my 1st tow bar refurbished (it was 12 years old then), Roadmaster had run out of parts for that model (it had been discontinued the year after I purchased it) but graciously sold me a new tow bar at their cost (approx. 50% off list).
Doug
2006 Jayco Greyhawk Model 27DS
Towing 2019 Ford Fusion Energi with Brake Buddy
willald
..Like the others, I would stronly suggest you reconsider going the 4 down route instead of using a dolly.
Especially since you already have a vehicle designed for 4 down towing very easily. Thats over half the 'battle' already won, right there! Most of us were not that fortunate when we bought our first MH! ๐Ÿ™‚
As to your specific points/reasons for going with a dolly:
I selected to go with a tow dolly to save wear and tear on the front wheel bearings, tires and front drive gear. Less expensive to replace tires and bearings on a tow dolly.
..Possibly, but if you do some research and asking around, I bet you'll find very, very few if anyone that has ever had to replace wheel bearings or front drive gear on a towed vehicle any sooner due to towing it (assuming they were using a vehicle designed for flat towing without any known issues). I don't think towing would add enough wear to bearings to ever be significant.
You do have a point about tire wear. However, once you factor in all the extra maintenance a dolly adds that you don't have with 4 down towing (2 extra tires, bearings, axle, etc), I think that pretty well evens out.
..Tow dolly has electric brakes so I don' t need an added brake assist on my toad nor do I need to attach brake lights since the tow dolly has them already.
Agreed about not having to add a brake assist, but NOT necessarily true about not having to attach brake lights. In many states, you will still have to have some kind of lights on the back of your towed vehicle even if your dolly has lights. Has to do with the fact that tail lights on the dolly are too far forward from the back of your towed vehicle, I believe.
..And I can tow any host of towable vehicles without the need for special towbars or towbar mounts. Towbars are vehicle specific which narrows your towing options.
Yes, you are right that the huge advantage of a dolly is that you can tow many different vehicles without modification.
However, to clarify this and prevent confusion: Towbars are NOT vehicle specific. The towbar itself is very generic, and can pretty much tow ANY vehicle within its rated weight limit. You'll typically buy ONE tow bar, and in most cases it'll work for every vehicle you'll ever tow behind the MH.
The part you're thinking about that is specific to each vehicle is the BASE PLATES, that the tow bar attaches to the car with. Those are indeed vehicle specific, but are not that terribly expensive - typically around $400.
...All things considered, if you already own a vehicle capable of flat towing, and is questionable if it even should be towed on a dolly.....IMO its pretty much a no-brainer decision. Put you some base plates on that Ford Escape, get you a ReadyBrute Elite tow bar (with integrated/included Readybrake braking system), put it on, hit the road and be done with it. You'll be glad you did later. ๐Ÿ™‚
Will and Cheryl
2021 Newmar Baystar 3014 on F53 (7.3 V8) Chassis ("Brook")
2018 Jeep Wrangler JK ("Wilbur")
DouglasC
Like "super camper", I too started out RVing in the early 90s using a tow dolly to haul my toad. That lasted for 2 years after which time I got rid of the tow dolly and have since installed tow bar equipment on 7 vehicles in the past 21 years.
The 1st 2 were Ford Escorts which needed a Remco lube pump for the automatic transmission. After problems with the lube pumps I vowed never to do that again so the last 5 vehicles that I've towed 4 down have not needed any modifications.
I'd never go back to a tow dolly or Remco lube pumps!
Also, one of my toads was a 2008 Mercury Mariner Hybrid (twin to the Escape). I towed that vehicle over 30,000 miles 4 wheels down - - no problems whatsoever.
Doug
super_camper
bsinmich wrote:
If I recall the Hybrid Escape does not need a dolly. It willtow 4 down. If I have to use a dolly again I give up RVing.
I agree with bsinmich, I don't have a alot of tolerance for things like this. We towed with a dolly for the first couple of years and won't do that again.
The issues we had with the dollay are
1. its bulky and has to be stored somewhere at every stop
2. its another set of tires, axles, brakes to maintain
3. by far our biggest problem was the dolly itself. It was a new mastertow and it completely fell apart. Search my previous posts about this, there wasn't a single piece of that dolly that didn't break down.
wcripley
I have a 2006 Ford Escape Hybrid AWD. I tow it with 4-wheels down, and was told by Ford engineers that they don't recommend towing with a dolly at all. I have not had a problem towing it all over the USA, sometimes 400 to 500 miles a day. I learned the hard way to double check and make sure it is not in gear when you tow it. Both times that I did, even though it was very brief and not more than 100 yards, I ended up with a problem where the car would die after a few hours of driving. It turned out to be a pump in the transmission. This has happened twice, and those were within a day or two of starting off towing the car with it in gear. Towed properly, 4-wheels down, ignition key in the accessory position with all electronics inside turned off, in Neutral, I have never had a problem.
I am fixing to buy a towed vehicle braking system for my Fleetwood Southwind and Ford Escape Hybrid. I have been looking at the US Gear Unified Tow Brake. Does anyone have any opinions or suggestions, particularly with the same rig?
Bill and Alma Ripley
KY5Q
Albuquerque, NM
Campnfuls
I selected to go with a tow dolly to save wear and tear on the front wheel bearings, tires and front drive gear. Less expensive to replace tires and bearings on a tow dolly. Tow dolly has electric brakes so I don' t need an added brake assist on my toad nor do I need to attach brake lights since the tow dolly has them already. And I can tow any host of towable vehicles without the need for special towbars or towbar mounts. Towbars are vehicle specific which narrows your towing options.
kyhawk
We tow our Escape flat. Why would you want a dolly? Just put it in neutral, release the parking brake, turn the key all the way back, and go. Our Hybrid is all wheel drive, so maybe that makes a difference?
Janet & Ralph
2008 Winnebago Aspect 26A
Campnfuls
bsinmich, just curious as to why you feel that way about tow dollies?
JohnnyT
Moved from class A forum
2004 40DS02 Travel Supreme ISL 400
Jeep Grand Cherokee, Ford F150
M&G Brake & Break Away
Blue Ox Aventa LX Tow bar
bsinmich
1999 Damon Challenger 310 Ford
