โJul-22-2013 02:23 PM
โJul-22-2013 07:05 PM
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
โJul-22-2013 06:59 PM
et2 wrote:sch911 wrote:
Yes Chrysler does know. We (yes we) put it right in the owners manual!
No! It cannot be towed on a dolly period. Serious damage will occur to the powertrain. 4X4 vehicles like these need to have all four wheels turning even when the t-case in in "N". There, you heard it direct from a Jeep engineer.
Thank you for your response. Unfortunately the person answering the phone at the Chrysler help desk wasn't helpful. Nor was the dealer.
I'm looking at the manual as we speak - again. Nowhere does it mention not to tow it on a dolly. There is instructions for 2wd towing on a dolly by the rear wheels. The 4wd can be flat towed but nothing stating not to put it on a dolly (4wd). So that leaves you to wonder if with the trans disconnect a dolly tow would work for the 4wd.
Actually the General RV service guy explained it in a way I could understand. There is too much of a angle (on 4wd jeeps) when being on the dolly and won't allow for the proper fluid circulation.
The reason I wanted a dolly is our lease will be up next year and we will be getting a new vehicle. It gets costly changing base plates every few years. This way I could tow just about anything on a dolly, except a jeep I guess.
Thanks for the help, much appreciated!
โJul-22-2013 06:55 PM
naturist wrote:
Fact: differentials are made to slip A LITTLE, but NOT to turn furiously for miles and miles. No matter what you put the transfer case into, at least one differential is going to be churning furiously, which will cause it to heat up. I saw a differential explode in flames, having gotten so hot the heavy oil in it vaporized, and when it blew out the seal and hit the air, it burst into flames instantly. This happened after a mere 30 miles on the interstate.
DO NOT ATTEMPT TO TOW A 4X4 ON A DOLLY. You will not like the results.
โJul-22-2013 06:13 PM
โJul-22-2013 05:02 PM
โJul-22-2013 04:45 PM
โJul-22-2013 04:03 PM
โJul-22-2013 03:58 PM
tandkj wrote:
Why put it on a dolly whren you can do 4 down? You have o find room at most campgrounds to park the dolly if the site is small. That is additional $$'s.
โJul-22-2013 03:50 PM
โJul-22-2013 03:23 PM
โJul-22-2013 02:36 PM
โJul-22-2013 02:25 PM
