Traveling with Propane on
Surgtech94
Do you travel with the propane on to run the refrigerator? What safety measures need to be taken? We havenโ€™t been traveling more then 1 1/2 hours from home, so our fridge hasnโ€™t cooled down much, but planning on some longer trips. Thanks In Advance
66 REPLIES 66
bikendan
Have been traveling with the fridge on propane for the past 30 years, with 4 different trailers.
Do leave it on electric during the night before and switch to propane when we leave.
Dan- Firefighter, Retired:C, Shawn- Musician/Entrepreneur:W, Zoe- Faithful Golden Retriever(RIP:(), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
bikendan
steveh27 wrote:
I precool my 3way fridge on electric then drive with it on 12volt. When I get where I'm going I will turn it to propane. If I need to get gas I turn it off at the fridge, gas up, and when out of the gas station will ignite the propane back on.
Very few RVs have 3-way fridges, usually only popups, A-frames and truck campers.
time2roll
valhalla360 wrote:
Of course, if that's the case, it has a ventilation system so the heavier than air CO2 doesn't build up...not to mention vehicles cruising at 30-60mph will move a surprising amount of air.
Mostly, it's a CYA.
I think it is caution for if there is a wreck. All traffic could be stopped and blocked with propane leaking.
rlw999
BB_TX wrote:
Theoretically there is a very slight chance that while filling up your and your RV was sitting next to a gas pump and the refrigerator vent panel was very near that gas pump hose as it was pumping gas and the wind was exactly right to lift the heavier than air gas fumes up and blow those into the refrigerator vent and the refrigerator was currently cooling and the fumes reached the burner, then yes, a fire is possible.
And it's not just your own pump you need to worry about, the guy on the other side of your RV might have tipped over the 5 gallon can he's filling, causing a pool of gasoline under your RV.
I saw that happen once, fortunately, he was on the other side of the pump island so the pool of gas didn't reach me, as soon as I saw it happen, I stopped pumping, pressed the call button on the pump to tell the store clerk, and moved my RV away from the island.
valhalla360
Navigator
Navigator
time2roll wrote:
ford truck guy wrote:
I went in and an inspector came out with their yellow and orange rain coat and clip board to WATCH me turn OFF the propane at each bottle..
did that, was good to go, merged into traffic and 1/8 to 1/4 mile later I was OUT of the tunnel :S
The tunnel has a dip that can collect the heavier than air propane.
Mostly, it's a CYA.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Michelle_S
When we had our TT and a Gasser TV, I would just pop inside and turn the fridge to OFF quicker and easier than turning both tanks off.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
CA_Traveler
Surgtech94 wrote:
Thank you everyone for the information. Yes, forgot our fridge was Automatic. But I believe I have to turn propane on and light stove to make sure propane is flowing to fridge? How do I know if fridge ignited on propane? TY
For a short fuel stop it should not be necessary to light the stove. But can be helpful to purge any air after storage.
My refer has a error light if it's not working on AC or propane. I can hear the noise when outside when the propane is lit but after a fuel stop the refer may not need immediate cooling.
2014 Grand Cherokee Overland
Bob
dedmiston
Moderator
Moderator
You should hear it flow and then a slight "whoosh" when it ignites. Also, your fridge should show an alarm if it doesn't ignite within a few seconds.
If I don't hear the fridge ignite right away, then I turn on a stove burner and then retry.
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โ€ข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โ€ข <\br >Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
mdcamping
I leave the propane on when fueling up at gas stations, ferry or tunnels I will shut the propane off.
Mike
2022 F-150 3.5 EcoBoost 4X4 Supercrew GCWR 19,500 157WB
Payload 2476 Maxtow 13,800 3.73 Equalizer 4 Pt Sway Hitch
2017 Jayco Jay Flight 24RBS
Old TV, 07 Toyota Tacoma, Double Cab, Factory Tow Pkg, retired towing at 229K. (Son now owns truck)
time2roll
Surgtech94
fj12ryder
pasusan wrote:
I actually don't turn it off when fueling and never have... But - I just posted this picture in another thread and look at what it says:
Danger!
Yeah, I think that falls under the CYA label. ๐Ÿ™‚
Howard and Peggy
"Don't Panic"
valhalla360
Navigator
Navigator
If your in a MH and the fuel fill is right next to the fridge or hot water heater vents, I might consider it. But honestly, I can't recall every spraying gasoline outside the vehicle and modern systems largely capture the fumes anyway.
But since it's the sparks that are a concern, do you disconnect and shut down the 12v system before you pull into a gas station...of wait, you can drive with the 12v system shut off. Unless you've replaced your alternator and starter with a marine spark protection...there will be plenty of sparks if there are any fumes.
Of course, out in the open air, it might startle you a bit but is unlikely to do much more. Kind of like too much lighter fluid on the campfire. You get a big whoosh but not much else. Explosions require the fuel/oxygen mixture to be contained.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
thomasmnile
Wasn't a propane fridge but......
For those who can never get enough of "Florida Man" stories.....:E
Martyn
Never turn it off.
Never Give Up
Never Surrender. ๐Ÿ˜‰
2020 Keystone Cougar Half-Ton 27SGS;
2019 Dodge Ram 2500 QC 4x4 6.4 Hemi BigHorn;
DEMCO Autoslide; 2 Honda EU2000i's;
Our Website
