I pulled 31 ft TT with a standard WD hitch and two sway controls and it worked great.
I also own Reese Dual Cam and there was no difference in they way the trailer behaved or felt with a standard WD hitch and two sway control bars.
#1 step is to make sure your WD hitch is adjusted correctly. You should not be experiencing ANY sway with just a weight distribution hitch and the trailer loaded correctly.
What is normally described as sway is really just normal push and pull 'wiggle' from passing vehicles. What you will feel is the bow wave from passing vehicles or gusts of wind. First you will feel the TT pushed then you will feel the TV pushed.
For me adding a single sway bar took a lot of the wiggle out, the second sway bar the rest out and made the trailer and truck feel like one unit while the wind blew and the vehicles passed.
If I get another TT it will have a standard WD hitch and two sway controls.
For my recommendation to you, I would buy a $50.00 second sway bar and run it before you spend $600.00 on a new hitch.
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
Itโs Kind of Fun to do the Impossible
~Walt Disney~
