Valterra valve cable question
WallynDiane
Our kitchen waste pull cable broke last week. The crimp that held the cable behind the valve pull failed.
I had the same problem on my black water valve cable a few years back.
My question surrounds the Allen wrench size needed to attached the exposed cable to the valve itself. The last time, I did not have that size Allen wrench in my tool box. I had to solicited fellow campers and I finally found the tight size. I failed to write down that size.
Does anyone know the Allen wrench size to use on the Valterra cable fixture?
I would like to buy one, but I don't know the size. Any tips on cable replacement are welcomed.
I purchased e Valterra cable on Amazon. Not too expensive. Thanks all.
4 REPLIES 4
deereone
Several years back I needed one for just the same thing and I think it was a 1/8"
dbbls
There are two kinds of Allen wrenches, SAE and Metric. I'll bet the two you have are the same. Get the one you don't have.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
WallynDiane
I have two Allen wrench sets. Both sets did not have the needed size.
therink
Why not purchase an entire Allen wrench set, not that expensive. If that won't work, I would go to the Valterra site and download the install manual. Maybe they indicate the size Allen wrench needed.
Sorry I can help with size.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
