โJul-07-2017 08:55 AM
โJul-07-2017 05:18 PM
โJul-07-2017 04:26 PM
โJul-07-2017 04:23 PM
travelnutz wrote:
We vote for bringing our own water and using it wisely and then leaving it behind at the dump stations. Our home water is pure and truly tasteless but many other locations have horrible tasting water and some that smell like swamp water or rotten eggs and taking a shower with that stuff makes you stink worse after than before the shower!
โJul-07-2017 01:08 PM
GordonThree wrote:
Green algae is growing in the tank.
I guess I could store the tank empty, but worry it might grow mildew which could be dangerous, compared to algae which is harmless.
โJul-07-2017 12:03 PM
โJul-07-2017 11:46 AM
โJul-07-2017 11:43 AM
โJul-07-2017 11:38 AM
โJul-07-2017 11:37 AM
โJul-07-2017 10:33 AM
โJul-07-2017 10:25 AM
โJul-07-2017 09:44 AM
โJul-07-2017 09:36 AM
SoundGuy wrote:DavidP wrote:
I use two 7 gallon aquatainers and a 12 volt pump with filter on output side to fill the tank. All parks are different but at some point you will need to refill. Lots of info on here with different methods to do that. Most SP's have a water source(s)to fill tanks. It is more about what works for you to gather it.
This. ๐ I've always carried four 7 gal Aquatainers in the back of my Avalanche for collecting fresh water from wherever the campground supply may be, recently replaced the Av with another Silverado so I just bought a fifth 'Tainer which means I can now collect 35 gals each time.
Back at the camper I too use a pump to transfer the water into the trailer's FW holding tank.
โJul-07-2017 09:27 AM
โJul-07-2017 09:20 AM
