water heater. presser
Ronhoward
Can get tank to fill but no pressure coming out at any faucet
Any ideas
When I by pass water heater plenty of pressure at all the faucets
7 REPLIES 7
hammer21661
Ronhoward wrote:
Got it fixed but had to pull tank out
Thanks for the ideas
What was it?
2018 Ram 3500 SRW crew cab long bed 4x4 diesel Lariamie 1-2018
2013 fuzion 322.8/25/2012
2000 Yellow Lab mix Dog, Earl,The One who gave me Unconditional Love picked up 9-12 or 13, 2001 till 2-7-2014 may he r.i.p.
Ronhoward
Ronhoward
Where would the check valve be? I have the bypass valve figured out I tbink. I will try to find the I check valve
PapPappy
Bad check valve, or is there a valve in the bypass system that is in the wrong position? It can get confusing?
Are you getting pressurized water coming out the pressure vent valve on the outside of the water heater? This would indicate that you are getting pressure into the tank, and that the "out" line is plugged or a valve is shut.
When testing, make sure the water heater isn't on, to avoid getting burned.
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau ๐Ÿ™‚
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.๐Ÿ˜ž
2000 Winnebago "Minnie" 31C, Ford V-10
Purchased April 2008:B FMCA# F407293
The Pets
bob213
Might be the check valve on the hot side of the water heater.
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
ibyers
Bad check valve on hot water heater.
hammer21661
Is the heater tank full? if it were full it should not affect the cold side.
